EvilBanshee
Everything posted by EvilBanshee
  1. you got a air leak somewhere dude
  2. I agree with the plug caps. I the the EXACT same issue. New plug caps. Ran like a champ. Buy brand new caps from Yamaha
  3. The way to really tell for MAXIMUM power, so to run on a dyno, and put a exhaust bung in that reads Air/fuel ratio. Keep leaning it out until the power starts to drop off. Then you know your perfect. USually peak power is around 13:1-14.5:1 Depending on the engine. Every engine is alittle bit different. I will agree "Peak" power on a spark plug soot ring will be less then a dimes thickness. But if you go with a dime thickness its safe and its close to perfect.
  4. The ideal Soot ring thickness for WOT jetting is the thickness of a dime. "Light light bown as thick as a dime" is darn close to perfect.
  5. your waaay fat. I would drop 3-4 mains
  6. Thats with bone stock nova. Firestone tires and exhaust manifolds. Stock cam. Stock carb ect
  7. This aint no Banshee. But this is what i do for another hobbie. Drag racing Muscle cars. Enjoy!!
  8. HOpe you guys enjoy. This is me drag racing a Small BLock LT-1 Nova
  9. FIrst of all what kind of fuel are you running? U deffinitly need to check fora vacume leak as the plugs are very different from left to right. But keep in mind if you are running pump fuel with 10% ethanol they will burn clean like that and look new if its burning a tick lean. if you are looking for 100% performance. you want to have the plugs looking more cleaner then black
  10. leave the mains. Change the pilot and your needle setting
  11. Vito's had issues with their 10mm cranks. They are junk, and i dont think they sell them anymore. NOw vito's 4mm crank is bullet proof. I run one and have zero problems.
  12. If you run good fuel. Crank it to +7
  13. More then likely you need a carb cleaning.
  14. i run it in everything. Chainsaw's, my sv650, my CFR450R, my F7, The race car. Its too bad they are trying to get in banned because it has lead in it. Because airplanes make so much polution in the world.... COUGH COUGH.. Maybe .0000075% ofthe worlds air pollution. Stupid governments and tree huggers...
  15. The truck driver who delievers to my place says its actual octane rating is 103. Maybe hes full of shit. I dont know. All i know is its good shit
  16. 100LL is 103 octane
  17. YOur compression ratio will be around 14:1. 93 octane is for engine with compression around 11-12:1
  18. I have the same set up. 22cc domes, +5 timing. I was wondering the same. I thought maybe 20cc domes max? But that may be asking for trouble. I wouldnt do less then 21cc domes on 100LL
  19. That is perfect!! Dont let anyone fool you saying its lean. They dont know shit. Ledded fuel runs Light grey even almost a white when it perfectly tuned. Trust me. Your fine. Been running 100LL for YEARS
  20. Your plug Gap is a .070?? AM i reading that correct?? .070!??? Dude thats your problem. YOur blowing out the spark. I would do .020-.025. Dont touch your mains. Try your plug gap first. YOur soot ring on the plugs dont look that bad.
  21. IF you run proper fuel,You wont have an issue running it on the lean side. Yes for sure you can go too far. BUt with my set up with 100LL i can run a lighter grey and still be on the safe side hands down.
  22. Alittle rich?.... You should see my plugs. Liiiiight liight grey. Sometimes almost a dark white. MAkes the most power where i have it set at. Ill post a picture some day.
  23. drop 2-3 main jet sizes. YOU ARE RICH as hell. Are you running diesel in that thing? LOL
  24. I would think MAXXX on a 421 cub would be with 21CC domes and plus 6-8 degrees. 100LL is awesome fuel. The actual octane rating is 103.
