wile climbing a long hill my banshee seems to run out of fuel, you can run it in high gear down a road for as long as you want it's ok, any body have this problem before and have a fix
Edited by toytech
I dont use one, but the dual pingel would solve your problem, thats what its designed for
thanks I'll try one
Man almost a bill for one :confused: Im glad my little stock motor wont need one for awhile :rotflmao:
yea they are expensive, but worth it so you dont run the bowls dry on the long passes.
cheaper than another set of pistons and bore job
I'd check float levels first unless you know that they're good then go dual pingle.
I took the original valve out of my tank tonight to put in the new one and found the screens mostly plugged up, I think the new pingle will fix my problem, so if anyone has this problem check the screens first before spending the money, oh well money well spent
Does it run right again? Thanks for the info on the screens. I probably wouldn't have thought of that one either.
I wont have it back to a hill for a couple of weeks, I will post up how it goes
