dusty_v141 Posted November 4, 2009 Report Posted November 4, 2009 Hey im porting my cylinders and was thinking about puting in some boost ports . I will be rideing trails and i own a motocross track so do yaw think it would make my power band too short. and what size would be good too go with; i have heard that if you make them too big not enough of the fuel mixture will go into the crankcase and will not get enough lubrication too the rod and crank bearings. is this true? thanks for all the replyes. Quote
J-Madd Posted November 4, 2009 Report Posted November 4, 2009 Are you familiar with porting Banshee cylinders? Quote
jbooker82 Posted November 4, 2009 Report Posted November 4, 2009 Are you familiar with porting Banshee cylinders? Its not hard you just hog everything out as big as possible. Quote
dusty_v141 Posted November 5, 2009 Author Report Posted November 5, 2009 (edited) im reading everything i can get my hands on and just trying too gain as much knowlage as possible about them while im saving too buy the tools i need Edited November 5, 2009 by dusty_v141 Quote
Screaming Yellow Zonker Posted November 5, 2009 Report Posted November 5, 2009 ok first question... what are your reasons for trying to port your cylinders?? Next in your sig it says -2 degrees timing... why not run advanced timing where it gives you power? If you are looking for more power advance your timing to 4* advanced and save your money for a cool head... Quote
dusty_v141 Posted November 10, 2009 Author Report Posted November 10, 2009 well when you advance your timing it gives you more power down low and takes away from your topend so if you retard it you get more topend. i was running asphalt and was trying some stuff and it does work. i also put at +4 and ran up the road too holding a gps and checked my top speed then did it at -2 and it was faster but not alot it just lets it rev farther. Quote
uwenr Posted November 11, 2009 Report Posted November 11, 2009 well when you advance your timing it gives you more power down low and takes away from your topend so if you retard it you get more topend. i was running asphalt and was trying some stuff and it does work. i also put at +4 and ran up the road too holding a gps and checked my top speed then did it at -2 and it was faster but not alot it just lets it rev farther. Holding a GPS?? I use the ol lick my finger and stick in the air to check my top speed. Quote
AKheathen Posted November 12, 2009 Report Posted November 12, 2009 Holding a GPS?? I use the ol lick my finger and stick in the air to check my top speed. i just open the barn door.......alot more sensitive than my finger......but i don't lick it... Quote
lmaloch Posted November 12, 2009 Report Posted November 12, 2009 Wow. Let us know how it turns out..... Quote
potpye Posted November 14, 2009 Report Posted November 14, 2009 You should have someone that knows what they are doing, you cant just hog the jugs out. Also you have to be careful when drilling the boost ports as you can go through the side of the cylinder real easy. Quote
dusty_v141 Posted November 14, 2009 Author Report Posted November 14, 2009 im done with them now and i didnt put the boort ports in ill wait and see if i like it how it is first. i ported them EXT 188* Transfers 125* 66% ext width and a blow down of 31.5. Quote
bad 350 shee Posted November 14, 2009 Report Posted November 14, 2009 can u post pics of ur port work Quote
dusty_v141 Posted November 14, 2009 Author Report Posted November 14, 2009 sure can anyone tell me how too post the pics i have a photobucket account but i cant get the link too work right. Quote
dusty_v141 Posted November 14, 2009 Author Report Posted November 14, 2009 (edited) here are thi pics of my porting. i have not polished the ext ports yet and im going too smooth the intake up just a little bit but not much. http://[/img] http://[/img] http://[/img] http://[/img] Edited November 14, 2009 by dusty_v141 Quote
SLORYDER Posted November 14, 2009 Report Posted November 14, 2009 Make sure you chamfer them there ports Quote
