333bbb333 Posted September 10, 2009 Report Share Posted September 10, 2009 Sorry if this is worded a bit weird, I dont know the best way to explain this, but I am trying to get this thing running and cannot get spark, I have tested stator and switches and all are reading correct, but still no spark. I tried testing the wires coming from the run stop switch (black in connector and Black/White thats separate from the multi-connection), they were good, But when I tested the wiring harness on the opposite connecting side going to the cdi, the black wire in the harness and the Black/White that is separate dont read anything, I get a reading when I go from black to a ground location. I disconnected the cdi and tested opposite ends of the black/white wire to see if it had a break in it, but it read good. Could this be a bad cdi or are these not supposed to have a reading like its connecting wires coming from the switch side. The only other issue I found was I could not get a reading from the secondary leads on the ignition coil, but when the bike broke down it was working fine, it just threw a rod.I was getting a good reading from the primary leads though. So I am lost on why I cant get any spark, and tired of spending money on unnecessary parts, any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
black sunshine Posted September 10, 2009 Report Share Posted September 10, 2009 This stuff can be frustrating. The only thing I can offer (other than the free bump) is to swap out the CDI with a known working one. Hopefully you know someone with a Banshee? Quote Link to comment Share on other sites More sharing options...
333bbb333 Posted September 13, 2009 Author Report Share Posted September 13, 2009 This stuff can be frustrating. The only thing I can offer (other than the free bump) is to swap out the CDI with a known working one. Hopefully you know someone with a Banshee? Thanks, but unfortunately no one I know around my area has a banshee, Ill just try everything else first and then break down and get a new cdi if all else fails. Quote Link to comment Share on other sites More sharing options...
pr0blumz Posted September 13, 2009 Report Share Posted September 13, 2009 Thanks, but unfortunately no one I know around my area has a banshee, Ill just try everything else first and then break down and get a new cdi if all else fails. Did you test the key switch? Quote Link to comment Share on other sites More sharing options...
Michael66 Posted September 14, 2009 Report Share Posted September 14, 2009 Sorry if this is worded a bit weird, I dont know the best way to explain this, but I am trying to get this thing running and cannot get spark, I have tested stator and switches and all are reading correct, but still no spark. I tried testing the wires coming from the run stop switch (black in connector and Black/White thats separate from the multi-connection), they were good, But when I tested the wiring harness on the opposite connecting side going to the cdi, the black wire in the harness and the Black/White that is separate dont read anything, I get a reading when I go from black to a ground location. I disconnected the cdi and tested opposite ends of the black/white wire to see if it had a break in it, but it read good. Could this be a bad cdi or are these not supposed to have a reading like its connecting wires coming from the switch side. The only other issue I found was I could not get a reading from the secondary leads on the ignition coil, but when the bike broke down it was working fine, it just threw a rod.I was getting a good reading from the primary leads though. So I am lost on why I cant get any spark, and tired of spending money on unnecessary parts, any help would be appreciated. Cheked the pickup coil gap to the flywheel?? Fixed my spark prob. Quote Link to comment Share on other sites More sharing options...
twizted269 Posted September 15, 2009 Report Share Posted September 15, 2009 you can also check the wires running along the airbox for grounding out on the pipe. i have seen them melt to the pipe and cause the same problem. Quote Link to comment Share on other sites More sharing options...
333bbb333 Posted September 16, 2009 Author Report Share Posted September 16, 2009 Did you test the key switch? The key switch is disconnected, the Black is looped back into the Black/White, thats how it was set up when I got the bike and it got spark then. Quote Link to comment Share on other sites More sharing options...
333bbb333 Posted September 16, 2009 Author Report Share Posted September 16, 2009 Cheked the pickup coil gap to the flywheel?? Fixed my spark prob. Not yet I will have to check that, thanks Quote Link to comment Share on other sites More sharing options...
333bbb333 Posted September 16, 2009 Author Report Share Posted September 16, 2009 Cheked the pickup coil gap to the flywheel?? Fixed my spark prob. What is the gap supposed to be, I could not find it in the clymers manual? Quote Link to comment Share on other sites More sharing options...
333bbb333 Posted September 16, 2009 Author Report Share Posted September 16, 2009 Also does it matter if the flywheel is rusted a little bit, it is more just discolored on the outside, rather than actual rust that is crumbling off or all rough looking. I was thinking this might be the cause to no spark, if this could prevent a spark can you sand the magneto clean? Quote Link to comment Share on other sites More sharing options...
pr0blumz Posted September 16, 2009 Report Share Posted September 16, 2009 (edited) Not yet I will have to check that, thanks Secondary test of the coil is from boot to boot, not like the manual says. Ohm the stator while you're at it. Edited September 16, 2009 by pr0blumz Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted September 16, 2009 Report Share Posted September 16, 2009 If the black touches the black/white you will have no spark,its grounding the cdi.Your key switch should be a red to a black Quote Link to comment Share on other sites More sharing options...
333bbb333 Posted September 17, 2009 Author Report Share Posted September 17, 2009 Secondary test of the coil is from boot to boot, not like the manual says. Ohm the stator while you're at it. I have tested boot to boot and pulled the boots off and gone right to wires, got no reading. I just put a new ignition coil on and still no spark. I am getting a good reading on the stator and pick up. Im starting to think its either my flywheel or cdi Quote Link to comment Share on other sites More sharing options...
333bbb333 Posted September 17, 2009 Author Report Share Posted September 17, 2009 If the black touches the black/white you will have no spark,its grounding the cdi.Your key switch should be a red to a black I have the red to black, just through the switch side not harness side, the switch side is black and black/white but they are the connects for the red and black on the harness side. Its hooked up the same way as it was when it was running so I know thats right. Quote Link to comment Share on other sites More sharing options...
nfk Posted September 17, 2009 Report Share Posted September 17, 2009 I had a similar problem, I tested everything and it tested good. I swapped flywheels with a buddy and it still wouldn't spark. I then swapped the CDI and that was the problem. You cant test it, you just have to try a different one that you know works. Some of the years have different connections so you have to check which one you have. Quote Link to comment Share on other sites More sharing options...
