big pit 007 Posted September 10, 2009 Report Posted September 10, 2009 so i bought my kid a grizzly 80. they said it just needed a spark plug. so i got a new one an it fired up but it will only stay running with the choke on. when u turn it off it dies and acts like its getting no gas. u guys are smarter then the ass monkeys where i live that want 100$ an hr just to look at it. any ideas would be greatly apprecaited! thanks Jason Quote
ISSUES Posted September 10, 2009 Report Posted September 10, 2009 Sounds like it needs a larger pilot jet. Quote
87sheerips Posted September 10, 2009 Report Posted September 10, 2009 Take the air filter off and make sure both needles are in sync and have full, smooth travel. I had a clip break off a needle once which caused the same problem. If not that, try a larger Pilot like stated above Quote
black sunshine Posted September 10, 2009 Report Posted September 10, 2009 Take the air filter off and make sure both needles are in sync and have full, smooth travel. I had a clip break off a needle once which caused the same problem. If not that, try a larger Pilot like stated above X2 on the pilot jet. 87Sheerips thinks your talking of a Banshee, that is why the crazy talk about synching and such. lol Quote
87sheerips Posted September 10, 2009 Report Posted September 10, 2009 X2 on the pilot jet. 87Sheerips thinks your talking of a Banshee, that is why the crazy talk about synching and such. lol Phhh, lol.. Guess I should read the post first, eh? LOL Quote
Duneman101 Posted September 10, 2009 Report Posted September 10, 2009 take the carb apart and clean it really well, then get a new air filter or clean the one on it real good. while you are cleaning the carb make sure all of the plugs and screws are in it. Quote
locogato11283 Posted September 10, 2009 Report Posted September 10, 2009 id pull the carb and clean the jets. if the pilot is not clogged, then id go up one size on the pilot. make sure your air filter is good and clean and secure. Quote
cummings0309 Posted September 11, 2009 Report Posted September 11, 2009 Your pilot jett is plugged up. I had the same thing happen many times. Quote
big pit 007 Posted September 11, 2009 Author Report Posted September 11, 2009 Your pilot jett is plugged up. I had the same thing happen many times. thank you guys! u are the best source of info anywhere! Jason 1 Quote
