Hey all, I have a problem where my bike stll rolls forward when i have the clutch held in all the way.
I tried adjusting the clutch cable on the handlebar first and that didnt do anything.
Then i took the clutch cover off and I dont understand why I would see the clutches loosen up (i could wiggle them with my fingers) when i would hold the lever in and then the clutches would grab on tight when i pop the clutch. Anyways i adjusted the center screw down there, put it back together and the damn thing is still doing the same thing..
Please help!!!
Edited by Alex29573
i took everything apart and THANK GOD my ball and rod came out very easily...
So now im not really sure what i'm looking for.. the manual has horrible black/white pictures that i cant really understand and this is my first time troubleshooting a tranny issue
Im going to post pics up in a little bit of what everything looks like.
Is the motor oil i put in yesterday supposed to be gray already?
How do i know if the clutch is worn out or good?
Make sure the plates are in the right order,check the adjustment on the basket, also make sure the preassure plate is locked in the grooves. also make sure the washer behind the inner clutch hub is behind it and not in front of it (lol I made all of those mistakes while putting my clutch back in ) :biggrin:
First pic-
I drew arrows to where i think there might be wear/tear. Not sure if this is a problem or is normal...
Also, the arrow on the top right corner, is pointing at a metal tab that im not sure what it does or if it even goes there...
Lastly, When i spin the outer clutch basket, there is a little play before the gear in the back starts to spin. Is this a problem?
http://i61.photobucket.com/albums/h62/alex29573/one.jpg
The springs are different colors and different heights -
http://i61.photobucket.com/albums/h62/alex29573/SN854037.jpg
Adjusting screw is warped inside the pancake bearing looking thing (i dont think this is an actual pancake bearing). I think the pancake bearing replaces this piece?
http://i61.photobucket.com/albums/h62/alex29573/SN854035.jpg
the manual says that there is a clutch plate, friction plate, and cushion ring. instead of 3 pieces, i have 2??? I also dont see that the clutch plates have cutaways so that i can align them 60 degrees from each other (manual)
http://i61.photobucket.com/albums/h62/alex29573/SN854042.jpg
rod and ball look ok i guess?
http://i61.photobucket.com/albums/h62/alex29573/SN854036.jpg
Case is banged up by inside
http://i61.photobucket.com/albums/h62/alex29573/SN854038.jpg
Edited by Alex29573
looks like someone already put in a after market clutch and alternated the springs. Thats why you only have the friction and steels without the cutaways and no cushion rings.
That basket looks wasted and should be replaced. The inner hub is showing some pretty nice grooving aswell.
If it were me.. I'd change the basket, inner hub, pressure plate and throw in a new clutch pack and springs. Couldn't hurty to buy a fresh cable. Make sure everything is adjusted properly and you should good to go.
ok, what do you guys reccomend i buy?
its not a heavily modded bike, its got 150 psi heads, pro circuit pipes, pro design intake, and 28mm carbs
what brand clutch? (i've seen EBC, YZF1000, and Vitos for under 80 dollars)
-a new OEM clutch basket or a Magnum basket (others are too much $$$)
since all that is being done should i modd my shift star and shaft?
Edited by Alex29573
