Ieat4strokes Posted July 27, 2009 Report Posted July 27, 2009 So everyone that does a 4mill have to have a override? This is my 1st 4 mill, drag ported by FAST and i cant shift under load at ALL, almost have to completly unload the tranny before itll shift past 3rd.....but everything inside is still stock, star, shift shaft etc....I do have the fast clutches and a d-d lockup though. would moding the shift shaft and getting a modded star help? I really dont want to go the dunable route but if I have to I have to......i race mostly 300ft dirt but i do like to still be able to play when i want, alot of open fields here.....I know alot of yall will say just get a duneable but my funds are kinda tight now, im going to have to send motor off to get this knocking sound figured out.....4 tear downs and still cant find what it is...... *cries* Quote
fastrthnu Posted July 27, 2009 Report Posted July 27, 2009 I have a ported 4mm motor with just a billet basket and it shifts just fine. well, not fine,... like any other typical banshee I should say. Quote
yamaha11 Posted July 27, 2009 Report Posted July 27, 2009 i had a 4mm passion motor and it would not shift either and it didnt have a lock up. so i had to get a duneable and i will never go back Quote
spurdy Posted July 27, 2009 Report Posted July 27, 2009 So everyone that does a 4mill have to have a override? This is my 1st 4 mill, drag ported by FAST and i cant shift under load at ALL, almost have to completly unload the tranny before itll shift past 3rd.....but everything inside is still stock, star, shift shaft etc....I do have the fast clutches and a d-d lockup though. would moding the shift shaft and getting a modded star help? I really dont want to go the dunable route but if I have to I have to......i race mostly 300ft dirt but i do like to still be able to play when i want, alot of open fields here.....I know alot of yall will say just get a duneable but my funds are kinda tight now, im going to have to send motor off to get this knocking sound figured out.....4 tear downs and still cant find what it is...... *cries* I am running a 4 mil from HJR with a DD clutch and no override. I have some work done to the gears, shift shaft and shift drum on bearings and I have no trouble shifting. Doesn't shift like an override under load but I can shift without the clutch 90% of the time. SP Quote
Ieat4strokes Posted July 27, 2009 Author Report Posted July 27, 2009 if you dont mind me asking, what he charge you for the work? PM me Quote
BigRed350x Posted July 27, 2009 Report Posted July 27, 2009 (edited) Side cut your gears, put the drum on bearings, shift star mod, roller bearing from cascade and you would have a good start. If you take some time and study the shift drum you can round some edges and put some different tapers in the tracks the forks ride in and make it shift even better. Then once you've done that you can play around with some different springs between the cases and forks and use spring tension to help the trans shift even more smoothly. Edited July 27, 2009 by BigRed350x Quote
RZBansheeMan Posted July 27, 2009 Report Posted July 27, 2009 Don't mean to preach all the "RZ" stuff on to people, but the RZ shift drum has a bearing and the shift forks also have roller bearings on the guide pins where the banshee forks do not, they are solid guide pins. :geek: Quote
Ieat4strokes Posted July 28, 2009 Author Report Posted July 28, 2009 Side cut your gears, put the drum on bearings, shift star mod, roller bearing from cascade and you would have a good start. If you take some time and study the shift drum you can round some edges and put some different tapers in the tracks the forks ride in and make it shift even better. Then once you've done that you can play around with some different springs between the cases and forks and use spring tension to help the trans shift even more smoothly. Yea but wouldnt having all that done cost about the same as a 1-5 dunable? I know nothing about the tranny, so I'd have to let someone else do it I just did my first complete teardown to put in the 4mill and now I have a knocking sound, so my confidence is kinda down at the moment..... squish piston to bore clearance and everything is a-ok.....still knocks, but the knock fades in and out, really notcible at idlegive it just a little gas and you cant hear it Quote
badassbanshee479 Posted July 28, 2009 Report Posted July 28, 2009 did you check the cushions in the clutch basket? grab the basket infront of the gear and try and turn it back and forth... if the basket turns and the gear does not... then the cushions are shot... I had a bike I could not find a knock noise and thats what it ended up being.... as far as the tranny goes, the shift star mod, shaft mod, and easy shift spring help.... but it still does not make it great... I have heard some people cutting every other "dog" off the tranny gears to help it shift better but I have never rode a bike with said mod.... Quote
locogato11283 Posted July 28, 2009 Report Posted July 28, 2009 go with a duneable override. you can drag it and still play ride it. if i had a trail banshee i wouldnt ride without a duneable. Quote
Ieat4strokes Posted July 28, 2009 Author Report Posted July 28, 2009 (edited) go with a duneable override. you can drag it and still play ride it. if i had a trail banshee i wouldnt ride without a duneable. wow, on a trail bike? so basically you can still trail ride it but not suppose to backload it right? But yea my basket does turn quite a bit without the gear moving, i asked about that in another thread..... so i guess i get to piss the wifey off even more.....sighs billet basket time hahaha Edited July 28, 2009 by Ieat4strokes Quote
locogato11283 Posted July 28, 2009 Report Posted July 28, 2009 wow, on a trail bike? so basically you can still trail ride it but not suppose to backload it right? But yea my basket does turn quite a bit without the gear moving, i asked about that in another thread..... so i guess i get to piss the wifey off even more.....sighs billet basket time hahaha i beat the hell out of my duneable on my 10mm cub. i can upshift under full power smooth as butter.. i can downshift with or without the clutch at any speed. ive never had an issue. Quote
