just did the whole enging now its together and we started it it idled with the choke on for a while then turned the choke off and the engine started to pick up so i got a screwdriver to ajust the idle then it started predetonating and sounded like it was running fuu throttle. so natrally i shit my pants and ripped the kill switch...didnt die,tore the wires out of the stator...didnt die,pulled of the plug wires...didnt die,tureded of the gas finaly died but it wasent because it ran out of gas.
i think she is ok i fixed a air leak and got through a heat cycle or two and it did it again :banghead:
could it be predetonating on low octane gas or assymbly lube on the piston
ist making a shit ton of compression
im not sure everybody in the shop that day was like wtf :shoothead: :shoothead: :shoothead:
btw the compression ratio is stock and i know shit ton isnt a good measurement but ill have real compression readings on monday or tuesday this week
please help :shrug:
thersno way the slides were stuck and i kow now there was a pretty massive airleak that has been fixed and it hasent done it since but what i want to know is why it ran after i killed the ignition was it predetination it sounded like someone was holding it wide open not sputtering popping or anythin just waaaaaaaaaaaaa
and a litle bit of wtf
Any chance one of your carb slides is getting stuck open?
x2 on this mine got stuck half throttle and predetonated and scared the shit outta me so i started pulling wires and shutting broken fuel shutoffs off that didnt stop fuel flow then i ripped seat off and plugged intakes with my hands here one carb slide was stuck open just a little bit put them in sync again and then try it.
  • 2 months later...
fresh rebuild it didnt even hsve the chain on it or i would have just poped t in gear and killed it but we know now it was the air leak must have been deseling from the assy lube and the lean mix confused me caus it was runnin so smooth. wasnt makin any unusual noise sounded sweet but was going ape shit
