Keyser Soze Posted June 26, 2009 Report Posted June 26, 2009 I was looking around for a thumn throttle extender and couldnt find anything for less than $40....What the hell its a little widget. Im sure someone on here can make them for much less and turn a good profit. Anyone know of a site that sells the for less than $40 shipped.................If not i'm taping a popsicle to my throttle. May even paint it black. Quote
dragbanshee Posted June 26, 2009 Report Posted June 26, 2009 Be pretty simple to modify something, or just man up! and endure the agony. Quote
AKheathen Posted June 26, 2009 Report Posted June 26, 2009 ride more often, and you won't notice it Quote
jbooker82 Posted June 26, 2009 Report Posted June 26, 2009 My banshee came with the extended lever. I took it off because I didnt like it. It was easier to push but it had a longer sweep. josh Quote
LiftdT4R Posted June 26, 2009 Report Posted June 26, 2009 Cheap easy fix is to switch to a 400EX throttle. Much better design, and easier on the thumb. I was never a big fan of the extended levers. Quote
odaen Posted June 26, 2009 Report Posted June 26, 2009 I like mine, personally. It's probably a little more than you are picturing though and most come with a bearing instead of the plastic stock bushing. Quote
4strokekilla1987 Posted June 26, 2009 Report Posted June 26, 2009 ride more often, and you won't notice it i always wanted to know why r ur pipes white Quote
RollinRhino Posted June 26, 2009 Report Posted June 26, 2009 Mine took some getting used to. The ones you see for $40 have the bushing and seal and you will need that bushing because the stock one is junk. Quote
BlasterKX Posted June 26, 2009 Report Posted June 26, 2009 i got the billet silver longer one and its a pain to get used to. but i bet when i put my 34s on it will be nice and easy Quote
someone82 Posted June 26, 2009 Report Posted June 26, 2009 (edited) I just tweaked my factory one to work for me. I removed the spring inside the the throttle housing (the pwk carb spring is more then enough) and bent the thumb pad to a better suited position. Been riding with it like that for two years now with no problems. Edited June 26, 2009 by someone82 Quote
dco3100 Posted June 26, 2009 Report Posted June 26, 2009 QUOTE (AKheathen @ Jun 26 2009, 03:50 AM) ride more often, and you won't notice it i always wanted to know why r ur pipes white Ha, me too Quote
ROBK Posted June 29, 2009 Report Posted June 29, 2009 I was looking around for a thumn throttle extender and couldnt find anything for less than $40....What the hell its a little widget. Im sure someone on here can make them for much less and turn a good profit. Anyone know of a site that sells the for less than $40 shipped.................If not i'm taping a popsicle to my throttle. May even paint it black. I got one from mooseracing.com for $25 Canadian, they have two different kinds. 1. bolt on and away you go 2. bolt on and adjustable. good luck Quote
