ROBK
Contact Methods
  • Website URL
    http://
  • ICQ
    Toronto Canada
ROBK's Achievements
  1. what should a 4 mil crank and port job cost me? and who do you guys recommend? I don't mind sending the motor out but also don't want to get killed in shipping
  2. Hi guys, I'm looking to get another Banshee but I want to know what would be the best year for a banshee I had a 99 banshee in the past an it was great, is there more desired year? also I want to know what would be the best set up to go with this time around, I mainly do trail riding and as always like to show up other quads when drag racing. I know its two different riding types but I guess i'm looking for a happy medium. budget for motor built $2000.00 I live in Toronto Thanks again Rob
  3. I got one from mooseracing.com for $25 Canadian, they have two different kinds. 1. bolt on and away you go 2. bolt on and adjustable. good luck
  4. Thanks buddy!!!!!
  5. Hi guys, I'm swapping out my stock clutch for a barnett clutch. When I pulled the stock clutch i noticed that I was missing a few of the cushion rings in between the clutch plates and since the barnett did not come with any do I need to put cushions rings back in or not? please let me know your thoughts Thank you, Rob
  6. The brand of Axle
  7. Anyone have any information on Bronco axles? any opinions on this axle? Thanks Rob
  8. So I was out riding today and sure enough my buddy rear ended me and bent my rear axle, I guess my question is should I put another stock alxe on? if not I would love to hear your thoughts Thanks, Rob
  9. Wouldnt happen to know where I can get the timing plate on line ??????
  10. THANKS GUYS, I will check all adjustments again, as for the motor its not a high hp motor. fmf pipes v force reeds I think the carbs have been changed and a mild port job when I got the top end done. I dont know much about this quad, just learning from this site I guess I have one more question, Adjustable timing plate ? please tell me your thoughts, Once again Thank you for all the help Rob
  11. Hello Banshee masters, A quick question for you guys, im having problems shifting when im in hi rev, then I have to let off the throttle and almost force it into the next gear. Only having this problem in 3rd, 4th, 5th, 6th Time to replace clutch? I am not sure what the problem is, If someone can help me out that would be great, Thank you, Rob
  12. Thanks man
  13. Hi guys, I just picked up a 99 banshee and am new to this site, (everyone I talked to told me if there is anything I need to know about a Banshee this is where I will find it) So I live in Toronto Canada, and need to get my self a new throttle cable along with a extended thumb throttle, I do have the tors taken off. just need to know where in Toronto I can get this? I know fast has it but with the doller the way it is it will cost me about $100.00 for just the extended thumb throttle (killer) Thanks guys Rob
