It's the counter shaft seal that's leaking, and it's an easy fix. If you don't fix it soon, the leaking oil will attract a bunch of dirt, and sand, and work it's way past the seal into the trans. This happened to me years ago, and caused the trans to quit shifting. I had to take the cases apart, to get all the dirt out, but luckily it didn't hurt any parts.
yah theres a gasket there and its really bad not to replace it because air will get in there and and that causes the motor to heat up alot
air wont affect anything with heat in the trans. there is a vent that allows air movement to begin with. change the seal to keep the dirt out like the others said.
that one of the stupidest things i have ever heard why would it cause heat, there is a crank case vent in the case from the factory, if anything it would make the crankcase run cooler
on a snowmobile ya , it is different that dosent have a crankcase like a banshee, so everything is lubercated by the mix of the gas/oil, so if you think about that, it would mean that you had a lean condition because of the extra air entering, aka unmetered air, which causes a lean condition, which is not enough fuel/oil mixture for the amount of air that its burning, this will cause everything to run hotter than it should
with the banshee having a crankcase that is lubercated with gear oil, and the crank which is sealed off from the crankcase it lubercated by the oil/gas mixed, now if this was leaking from a crank seal then you would be right, but since this is from the counter sproket shaft you are wrong
daa. im los of words rate now i cant belive i said all that. i been so bussy working on my snowmobile and jetskies i just remembered its not like a snowmobile were the couplings come off the crank shaft. it sounds confusing what im saying but i cant really explain my stupidity on this 1
Has your bike thrown the chain lately? If so take a close look underneath the sprocket and see if it's leaking from a crack in the case, I thought my seal was leaking until a found a small crack.
What? We better plug the breathers then
