travis6767
Everything posted by travis6767
  1. would you sell these for 250? let me know thanks
  2. i have a banshee that i would like to trade for a 450r, 400ex, suzuki450r, or yfz450, the bike needs to be clean and worth as much as mine. banshee has different pipes on it in pic and also has holeshot rear tires on it now mods are Trinity pro mx port and polish cylinders head had been milled and domes are reshaped has paul turner mid range pipes k&n pod filters +2+1 a arms elka dual rate shocks with piggyback rezzis gforce axle +2+4 ac racing pro peg nerf bars tag front bumper ac frame skid plate orange powdercoated frame engine has been taken apart and cleaned has billet clutch basket every piece of the clutch is brand new with a pancake bearing added
  3. the clutch basket will go on any way, not really a certain way to put it on. and the arrows on the friction plates need to be spread out evenly on the basket
  4. anbody got a set of pt high revs or mids laying around that they may sell?
  5. anybody have paul turner mid range pipes they want to sell please let me know thanks
  6. i have a banshee engine with trinity ported heads (pro mx port and polish) head has been machined has swirl in dome they are .030'' over stock bore, the crank is stock length it is trued and welded, every part of the clutch is new inner outter clutch hubs are new rod and ball are new clutch rod/linkage/arm is new, billet clutch basket, new pancake bearing from fast racing, this engine is built right runs like a mother fucker, the clutch case is powdercoated HD orange, this is on ebay right now, i am wanting to put the yfz engine in my banshee so let me know what you got i would possible trade for a honda 450r engine to the engine has to be in good shape because i want to put it in my banshee and ride
  7. i have a stock banshee axle that will work, it will just be like 2 inches wider which is better anyways let me know id let it go for 45 its in good shape not bent or messed up
  8. thats what i ment, dont have to be a smart ass and it is part if the crankcase because it is the case that houses the crankshaft
  9. ok i got a stupid question to ask, when you check the oil do you just put the dipstick in without screwing it in or do u screw it in then screw it out to check it?
  10. i will give you 150
  11. www.hsdracing.com
  12. i know a place that sells the dualrate elka with rezzie and with the linkage for $850
  13. are your pipes in good shape? i have t-5 i might trade
  14. well i fuigured out the problem, the wires were loose in the connector where the stator plugs in to the wiring harness thanks for the help guys
  15. nope didnt check, kinda hard to if he lives out of state, so thats why i just thought i would ask and see if anybody had done this
  16. well i checked it for spark because now it doesnt run at all, and found that about 2 out of every ten kicks i get a spark
  17. last night i was gunna go ride so i started the banshee up to lad it in the back of the truck and it ran fine, i get out to the ridding spot and get it unloaded, it stars right up runs fine sounds good take it through the field and it starts cutting out on the way back, i get back to the truck and it hardly runs, just popping and sounds like shit, sounds like it is not sparking all the time, but i know for sure its getting gas, so if you have any ideas of whst this could be let me know i gotta get it fixed. and it was missfiring out both cylinders
  18. has anybody tried to put a shock from a trx450r onto a banshee, because my friend has one and he said i could have it if it would work.
  19. On a stock head is the whole thing flush with the coolant port on the head? Just wodering because if that's the case my head has been milled .090'' and the domes have been reshaped. So if that is true what compression ratio do you guys think I have . Stock stroke with wiesco pistons. And its been bored .030'' over stock
  20. Is there a way to get the ball and rod out when welded together without spliting th case open?
  21. well i was riding my banshee tonight, and it was running good then all a sudden i went to pull in the clutch and it felt like the clutch cable broke, but it wasnt the cable, the clutch rod that sticks outta the case was stuck in the disengaged position, does that sound like i welded the clutch rod to the little cluthc ball?
  22. well i was riding my banshee tonight, and it was running good then all a sudden i went to pull in the clutch and it felt like the clutch cable broke, but it wasnt the cable, the clutch rod that sticks outta the case was stuck in the disengaged position, does that sound like i welded the clutch rod to the little clutch ball?
  23. trail tech makes a mount that you can buy, or rockymountainatv.com sells a universal bigbars clamp kit. hope this helps
