ok right now i have stock stroke cylinders with mx port and polish, and if i was going to put a 4mm stroker crank in what all would i have to do, i would like to keep these cylinders because they are one of the cleanest port jobs i have seen, can someone let me know every part i would need to do this?
thanks
thanks
The first thing you need to do is find out whether or not your cylinders can be ported to match the 4mm stroke. Contact the shop/builder that did the cylinder porting and get the run down before you commit to the build...
A 4mill will most likely have 115 rods. so all you need is long rod pistons, cut the domes/or add a spacer that I don't recommend, then ask your builder who ported your cylinders and see if you can raise the exhaust 2mm or not..
It can be just a bolt on with a spacer plate and pistons. This will make more power than a stocker. If you want to make real power get in touch with a builder. You will need it ported and I like to run without a spacer plate. I like to run a cool head and custom domes. Also a timing plate and a set of good pipes.
whats wrong with the spacers? it doesnt make sense to do the spacers, doesnt that defeat the purpose of doing the longer rod? trinity was the place that ported them, but it was like 4 years ago, i heard that they are kinda shitty now, so all i need to do is find out if they can open the port window to match the 4mm stroker piston's window right?
If the transfers have been lifted at all the spacer will make the durations to big. Then the motor will not want to rev out.
Yes, match the port windows and make sure the durations are not too big.
Listen to this man^^^
He built my play motor and it rips hard...
Need to call and get a set of methanol domes Kev. Got shearers and meth on that thing now and it hauls ass...
Glad its running good for you. Meth is your friend :blink: :biggrin:
