2slow350
Everything posted by 2slow350
  1. I was about to say try balancing them although ive never done this w any of my banshees, but definitely recommend balancing 4x4 4whlrs..
  2. I've ever broke in a bike by running too big of jets..
  3. If you think you'll ever run front brakes again or want to, I believe jjanda makes them with rotor mounts.. I don't know if anyone else does this..
  4. Like he said, put the stock stator back on.. You can't trust a Ricky stator period, they are all Junk!
  5. The bottom case studs are the hardest to get out, even the snap-on stud puller will strip them.. Take your time and work with them, maybe use a lil heat.. Other than that good luck!
  6. Very true, I've seen people time after time with big motors in a stock chassis go to the track a get it handed to them by a small motor whether in a stock chassis or drag chassis.. You can really just get to much power for a stock frame if not set up perfectly.. Jmo..
  7. Yep, spend the money and go with JJandA..
  8. It could depend on alot of things to get the best performance out of your setup.. For example, are you drag racing, your weight, tire size, tranny, etc.. But yea a 14-42 should work.
  9. I run klotz super-tech in alcohol and gas and never had any problems, but castor 927 is really good oil too. My experience with 927 is I wound recommend purging it after every ride with alcohol bc it separates unlike klotz when it sits.. Jmo.. 50:1 is a lil lean to me on gas, I run 32-40:1, and around 24-28:1 on alky..
  10. Sounds lean to me, maybe back the timing down to 5 or 6 degrees.. Jmo
  11. 12,000 on a cub? Ha, for that much money you can go much faster than a cub :biggrin:
  12. I agree, I've seen stock Carbs pull 70-75hp.. But i believe there's to many variables here to really tell you anything.. Jmo
  13. Yea, I also believe they have a 10mil stock cylinder that ran a 3.7. Very fast stuff..
  14. If that's what you wanted, the bike is worth the money.. One on the best looking hillshooters I've ever seen hands down!!
  15. Now that was an ignorant statement, and yes I know NOS is a brand.. Oh, and by the way not all of us on this site are "Just into Banshee's" :biggrin:
  16. My buddy has a set of cubs that I know for a Fact kim ported, and don't have his name on them.. So not all the cylinders have his name on them. But I do see having kim's name on them do help when selling to others... Have they been ran and I'm guessing they don't come with pistons?
  17. Yep, what he said.. I believe the most common are 39pwk's. But if you want to spend some money, you may want to try electrons..
  18. Yep, 65-75 bucks Noss can even have them to you the next day seeing your from Oklahoma too..
  19. I agree, I don't know why people always liked dmc's.. Personally I like t5's better than dmc's on a stock bike.. Cpi's and shearer's are just damn good pipes, hands down!!!
  20. 2slow350
    Hey new.
    I would just go ahead and keep the bike the way it is and save your 5000 up in a year and buy a banshee that will run in the 6's... You can buy alot of bike now a days for 5000... JMO !!
