Wiz Posted December 8, 2008 Report Posted December 8, 2008 Just curios what everybody runs for case oil (tranny oil) and why? is there a reason? what have you had not such good luck with? I used to run the Maxima MTL and had good luck with it but I got introduced to the Redline Ultra Shockproof Oil and after using it then doing a teardown there is nothing I will ever use besides this stuff. It coats and puts the best film on parts of any oil I have ever seen, I am sold... Quote
POORBOY350 Posted December 8, 2008 Report Posted December 8, 2008 i use maxima. but sounds like you've found the best stuff, right? i think alot of it is the same it comes from the same place! Quote
AKheathen Posted December 8, 2008 Report Posted December 8, 2008 did you notice any difference in your clutch? Quote
itsaripper Posted December 8, 2008 Report Posted December 8, 2008 OK This gets brought up about as much as "what is the best pipes? So I will throw it out there first. I USE F-TYPE AUTOMATIC TRANS FLUID. I have used it for five years and never had any trans problem. It shifts great and I change the oil at about twenty hours. It's cheap about $2.35 a quart hear. I have read all the reasons people think that it won't work. But you know what it does. So everyone will use what works for them. Just one caustion don"t use Dextron it has slicking agents in it, where the F-type makes the clutch grab. Quote
AKheathen Posted December 8, 2008 Report Posted December 8, 2008 OK This gets brought up about as much as "what is the best pipes? So I will throw it out there first. I USE F-TYPE AUTOMATIC TRANS FLUID. I have used it for five years and never had any trans problem. It shifts great and I change the oil at about twenty hours. It's cheap about $2.35 a quart hear. I have read all the reasons people think that it won't work. But you know what it does. So everyone will use what works for them.Just one caustion don"t use Dextron it has slicking agents in it, where the F-type makes the clutch grab. is that 5 years on a new engine? or did you have regular oill for a while before that. just wonderin because i was wanting to switch to atf, but it's had conventional oil for over 3 years, and seals don't usually like big changes in oil type. Quote
jamebo Posted December 8, 2008 Report Posted December 8, 2008 Yamalube sae 10W-30, no probs here :thumbsup: Quote
shanYE west Posted December 8, 2008 Report Posted December 8, 2008 is that 5 years on a new engine? or did you have regular oill for a while before that. just wonderin because i was wanting to switch to atf, but it's had conventional oil for over 3 years, and seals don't usually like big changes in oil type. It dont hurt the seals... I've switched case oils every other week.. all depends on what I have at the time.. I've swtiched from gear saver to 10w30 to MTL to type F back to gear saver back to type F.. hell I've even used belray thumper oil. No problems here.. As long as its for a wet clutch.. I'll use it. Quote
AKheathen Posted December 8, 2008 Report Posted December 8, 2008 It dont hurt the seals... I've switched case oils every other week.. all depends on what I have at the time.. I've swtiched from gear saver to 10w30 to MTL to type F back to gear saver back to type F.. hell I've even used belray thumper oil. No problems here.. As long as its for a wet clutch.. I'll use it. cool beans :thumbsup: i was just worried, cus i have a 4 runner that pissed everywhere when i used ps fluid in the power steering instead of atf. when i switched to synthetic blend, then synthetic, it did the same on the engine.... i don't like switching anymore i've done other cars and trucks with the same story as well, so when it comes to automotive, stick with what u got, unless it's a cartrige seal- i havn't seen those fail from that yet Quote
Big_Dave Posted December 8, 2008 Report Posted December 8, 2008 does anyone have a prefrence to what they use? Quote
BlasterKX Posted December 8, 2008 Report Posted December 8, 2008 alot of people around here use automotive engine oil but i use Honda Performance tranny lube. its meant for wet clutches and reduces slippage and wear. good stuff to Quote
dajogejr Posted December 8, 2008 Report Posted December 8, 2008 ATF Type F and change it every other time at the track. I used Amsoil Gear oil for 2 strokes and it was garbage back when I had a stocker w/ bolt ons. Went back to Gearsaver 80W and it was fine.... Quote
shanYE west Posted December 8, 2008 Report Posted December 8, 2008 I use atf type-F also, I also used Bel-ray gear saver, Maxima MTL, Klotz flexdrive, Honda 80/85 gear oil. All work well.. Quote
Soupbox660 Posted December 8, 2008 Report Posted December 8, 2008 Ive always used Bel Ray Gear Saver 80w, never had any trouble, love it and probably wont change. Quote
tapout94 Posted December 9, 2008 Report Posted December 9, 2008 ATF mercon VI... as recommended by the real mccoy... Quote
F.T.W. Banshee Posted December 9, 2008 Report Posted December 9, 2008 ATF mercon VI... as recommended by the real mccoy... Any body ever try the klotz trans fluid. I hear that is sussposed to be the best. I know ther 2 cycle oil is. Quote
