Well I finally moved up and need a good start for jetting for new set up. The old set up was jetted perfectly.
Old set Up
Stock Carbs with tors removed and idle screws installed
340 mains
27.5 pilots
Airscrews 1 1/2 turn out
Stock Needle on 3rd Clip
Intake with crossover tube built in
Stock bore jugs
VF3's
T-5's
K&N Pods with outerwears
Noss machine cool head with 20cc domes
+4 timing advance
sea level for elvation
60-70 riding temps
New set up
33 PWK's
mains?
pilot?
airscrews?
needle type and position?
4 mil long rod crank
795 series pistons
cut domes
stock bore aggressive dune port to match 4 mil
VF3's
T-5's
+4 timing
sea level for elevation
60-70 riding temps
I need all the help I can get. Thanks in advance.
Damn, your going to have a hell of a grin on your face when you come back from that 1st ride. good luck!
That's what I'm hoping...I literally man handled the old set up and figured I already had all the bolt ons, so it was time. :biggrin:
Mine is fairly close to yours. Sea level, 165lbs static compression and I run a 50/50 mix avgas 100LL/pump premium 91 octane.
Specs are in my sig.
152 main, 3rd clip, 48 pilot.
Edited by jayzx750
