broke
Everything posted by broke
  1. What the title says.
  2. Aren't those motors awesome?
  3. Since I can't edit the post, this is the picture of the entire clutch.
  4. Here are the pictures of the clutch, with two close ups of the basket to show the wear.
  5. I believe the chassis is sold. The Elkas will not work on a Banshee. RZ jugs 4mm crank 12 port RZ shift forks/drum Carbs are 32mm Lectrons. The only stock parts on the motor are the cases and the clusters.
  6. Believe it or not, my PTR mids liked a fatter pilot jet than my CPIs.
  7. That wouldn't take me long, I just don't have any measurements for the stock standards.
  8. I'm selling everything you see in that picture. $400 shipped for them.
  9. The motor will start coming apart in the morning and I will take close up shots of anything you want. I can also mic everything if you would like also.
  10. Magnum Basket w/gear Fast fibers and steels HD springs inner hub pressure plate pancake bearing 15 hours on entire set-up $200 plus shipping Quick change clutch cover $125 plus shipping You can see the cover in this picture, but I will get close ups as the motor comes apart on Saturday. The complete motor will be on here eventually if anyone is interested in any other parts.
  11. All I can tell you is that I spent five years trying to build a trail Banshee. I tried just about every part mentioned above. In the end I ended up with a 250r geometry RZ motored bike. I will say I am just as fast as any 450 in the woods and rip them up in the straights. A better rider could probably really push this thing to be insanely fast, the only limit to the bike right now is the pilot.
  12. $200 The entire set up has around 10-15 hours on it, all trails. Magnum basket with gear FAST fibers/steels/springs inner hub, pressure plate pancake bearing It has RZ shift forks and drum in it if you're interested in that as well.
  13. The RZs are kind of a pain in the ass when you are building them, but you will be much better on your second try.
  14. They really are easy to build. The parts can be purchased cheaply at a muffler shop.
  15. Dependind how extensively that exhaust port was cut, I would say straight 110 is what that motor needs with 16cc domes. I would start there, it might be detonating to bad to ever have good top end.
  16. I have a set of Rockets, built by the original builder before the company was sold. $400 shipped.
  17. I not real sure how to say this, but uh....no thanks, but tempting.
  18. The complete bike is $5200 Chassis is $3500 with shocks $2700 with out The motor is not running right now so if nobody wants it it will be parted out and the chassis will be sold motorless. All prices are firm, I'm letting this go cheap and for any less, it's going to leave in parts on Ebay. Shaffer Chromoly LT chassis, swing arm and +3 A-arms, adjustable wheelbase. Elka quad rates, SSD front and rear Passion built 12 port 4mil RZ motor The motor has RZ jugs and head(cut for 110) Banshee cases RZ shift forks and drum Banshee clusters Fast Racing clutch with pancake bearing(Basket, fibers, steels, pressure plate, inner hub all have about ten hours on them) Prodesign billet intakes Lectron 32mm carbs Rocket pipes Quick change clutch cover Durablue axle Hubs to convert Honda spline to Banshee bolt pattern(expensive durablue part) Durablue Sprocket and brake hubs Shaffer Chromo stem with LS antivibe clamp -400ex spindles, rotors, hubs, calipers -no link swingarm 250r -ac pro pegs -+ 4'' durablue axle 250r -250r rear caliper -250r antifade locknut -custom alumnium airbox w/ yz filter -lightened flywheel The bike is awesome, it's hard to describe unless you have ever ridden one. The motor makes hp around low 70s when tuned right, but has an insanely broad powerband from the Powervalves.
  19. There has been alot of interest in the Chassis alone and I do not mind parting this out, but most of the chassis is either Honda of frame specific so the chassis goes as one piece. The chassis is everything minus the motor, pipes, carbs, electronics, wheels and tires. The motor is not running as of right now, so the only way I would feel right selling it is as parts, then all the parts could be checked as it came apart.
  20. I hate to sell this thing, but it's got entirely too much dust on it. The bike does not run right now, it might be something simple, I just don't have any time to work on it. The price drop reflects that the motor currently does not run. The price is firm. Shaffer Chromoly LT chassis, swing arm and +3 A-arms, adjustable wheelbase. Elka quad rates, SSD front and rear Passion built 12 port 4mil RZ motor The motor has RZ jugs and head(cut for 110) Banshee cases RZ shift forks and drum Banshee clusters Fast Racing clutch with pancake bearing(Basket, fibers, steels, pressure plate, inner hub all have about ten hours on them) Prodesign billet intakes Lectron 32mm carbs Rocket pipes Quick change clutch cover Durablue axle Hubs to convert Honda spline to Banshee bolt pattern(expensive durablue part) Durablue Sprocket and brake hubs Shaffer Chromo stem with LS antivibe clamp -400ex spindles, rotors, hubs, calipers -no link swingarm 250r -ac pro pegs -+ 4'' durablue axle 250r -250r rear caliper -250r antifade locknut -custom alumnium airbox w/ yz filter -lightened flywheel The bike is awesome, it's hard to describe unless you have ever ridden one. The motor makes hp around low 70s when tuned right, but has an insanely broad powerband from the Powervalves.
  21. I'll bring this one up too. $5200 firm. It does not run right now. I don't know what's wrong with it, it might be something simple, but I have no time to work on it.
  22. $5200 firm. It has some kind of issue right now and won't run. It might be something simple, I just have no time to work on it.
