locogato11283
Admin
Everything posted by locogato11283
  1. What color is the spark plug strap? If it’s tan, you’re really close on the jetting.
  2. Big carbs and Shearers on a stock stroke motor will do that. Stock carbs would likely yield better results up top.
  3. You need to get some legit carbs ASAP before you burn it down. 156 main would be a Keihin style carb jet size. Most Keihin carbs I’ve run take 45-50 pilot and 155-165 main. So it’s probably not too far off.
  4. 33PWK is a safe bet. Should be stupid simple to tune.
  5. Do you really think all of a sudden Green got smart and could read French? Fuck no. He used translator.
  6. Bonjour, bienvenue à BansheeHQ! Nice Banshee. Claude aime toucher les petits garçons, alors faites attention. Il pourrait aussi vous envoyer des nus.
  7. I would go Alba +2 LT arms with Fox Float Evol and Fox Podium in the rear. Excellent set up.
  8. Recreation is up since people aren't traveling. It's just a supply and demand thing really. Stock ones have always been high, but it's not a buyer's market right now.
  9. Powdercoating would be way easier and likely turn out better.
  10. Sounds tough. Why not powder coat?
  11. I’m pretty certain they don’t need to come out for powder.
  12. Suspension..
  13. No. Only change one thing at a time also.
  14. Fox Podium rear and Floats in the front. Never look back. If you opt to keep your OEM rear shock, you really don't need a revalve. I have run OEM with different springs on everything from +2 to +14 arms. What kind of budget are you looking at?
  15. Seems to me at that elevation, you probably don’t need a 30 pilot. Have you tried a 25 or 27.5. Here at 1,000’, 27.5 is most commonly used.
  16. I’ve never had any out. I’m guessing the press in?
  17. So when you choke it when cold it doesn’t want to start? I’m guessing too much fuel. Try a 27.5 pilot.
  18. Yes. I think I have spacers or washers between frame and shock and/or arm and shock.
  19. That’s something that happened quick most likely. Either a massive air leak or no fuel.
  20. They are Warrior shocks.. I run Fireball drag arms. https://www.ebay.com/itm/FOX-FLOAT-3-FRONT-AIR-SHOCKS-13-DRAG-RACING-LOWERING-YAMAHA-BANSHEE-350/382372142396?fits=Year%3A2013|Make%3AYamaha&epid=1134379311&hash=item590727dd3c:g:2K0AAOSw~oFXHqUv
  21. Holy shit.. You likely had a serious loss of fuel. Is that a stock crank?
