caleb90
    38
Everything posted by caleb90
  1. Isnt that where vitos is located?
  2. Did you check the choke circuit to make sure the plunger is not hung up, causing a rich condition?
  3. Did you run a compression test on the left cylinder?
  4. Pull the stator cover and check the timing, and flywheel key way
  5. Good job... Admin needs to make it a sticky....sKeEtEr... Specialblend woulda had it done yearrrrsssss ago
  6. I have the modquad one that i used on the oem swinger
  7. Waiting for some with the same set up, before i start hacking away
  8. The two tabs that clamp over the swing arm?
  9. Getting my fireball swingarm installed, bought a new tm design chain slider kit. The axle slider keeps popping off the swingarm and getting pushed into the frame when i tighten it down.. you guys run into this? Sent from my moto g play (2021) using Tapatalk
  10. Niche.... Amazon day have da cool link colors
  11. Is the swing arm oem or some thing off brand? Aka vitos? Id put the top shock bolt in first, let the swing arm drop then use a punch on the linkage to help coax the lower bolt in. It is possible that rear shock was altered with shims to give it a longer eye to eye length
  12. You sure the swing arm is movine freely and dropping dow fully?
  13. Jeff is sending new ones
  14. Here is the other pod Sent from my moto g play (2021) using Tapatalk
  15. These are fast brand pods took em off to clean , i have never been a fan of k&n filters as they can dust motors. Might have to try and find uni pods Sent from my moto g play (2021) using Tapatalk
  16. Oem gasket put on dry. If its o rings for an after market head, use some grease to help hold the orings in place when installing head
  17. Took it out to clean the tank out. Had cali sand in it from previous owner. Dropped it and snapped the end off for the on pick up
  18. Dropped my petcock and broke it, is it worth spending the extra coin on a pingle for a 70hp motor with stock carbs
  19. 500 bucks now , or thousands later.. fast is a good shop
  20. The lines with the t are the crank vent hoses
  21. The top line from the bottle is the over flow and it runs up to the steering hoop and sits in a L tab on the hoop. The bottom hose runs to the radiator nipple
  22. I think im going to try 303 areospace spray
  23. That gear oil tho
  24. Never worried or have sprayed my plastics before. Is sc1 worth the money or are there cheaper alternatives?
