caleb90
    38
Everything posted by caleb90
  1. Mine dont go that far. The dot on my slides go half out of the window at wot
  2. Mine go past the windows. They are there for checking the sync, not as a slide stop indicator
  3. Isnt the biden admin making an ex order agaisnt our firearms today?
  4. Im down with milfs
  5. Rattle can them gold flake
  6. ^
  7. Well i stand corrected. Never seen any thing like that.
  8. Those holes are blind. If its leaking some one drilled it out..
  9. Will say what those blind holes are for
  10. I think you should get a service manual, read and re read
  11. You suck..... 2006 time capsul
  12. 10-4.. the clutch cover i want with the reinforment ring, gasket kit and bearing pressed in by direct drive. Is the same price as the direct drive kit redline sells
  13. 60-70 ? 4mill long rod, fast play/dune port, pump gas, slp pipes, timing. Mild build
  14. Going to be ordering my direct drive clutch cover. Currently i am running fast's hd clutch kit, trying to decide if i should stick with that or get the lock out with the cover. What are the pros and cons to the lock outs? Thanks
  15. Steel
  16. Return cost is 10bucks. F that, if any one needs an axle nut for a tusk axle lmk can work some thing out
  17. Tusk axle just came, i did not read the description when i bought it and orderd a axle nut. So now i have an extra, i have never used them is it worth hanging onto? Or return it and get my 50bucks back?
  18. Hinson is good. Chariot sells on ebay you should be able to get it shipped over seas
  19. Put it on a jack stand, have a buddy hold her pinned in 6th gear while you use 2000grit sand paper to polish er up... Let us know how it goes
  20. You work there?
