ClaudeMachining
    110
Everything posted by ClaudeMachining
  1. Dam, i'll pay the difference!! Envoyé de mon SM-G965W en utilisant Tapatalk
  2. Check compression and report back. Envoyé de mon SM-G965W en utilisant Tapatalk
  3. If it's a modded oem, no problemo. Envoyé de mon SM-G965W en utilisant Tapatalk
  4. 75hp. Envoyé de mon SM-G965W en utilisant Tapatalk
  5. I'm bored, reading stuff. Envoyé de mon SM-G965W en utilisant Tapatalk
  6. https://r.tapatalk.com/shareLink/topic?url=https://www.bansheehq.com/forums/index.php?/topic/164788-racetech-electric-high-output-banshee-stators/&share_tid=164788&share_fid=14738&share_type=t&link_source=app Envoyé de mon SM-G965W en utilisant Tapatalk
  7. I do the same thing with all my engines. I do 3-4 heat cycles, then i go easy (no extended wot) for the first tank or so. That's about it. Envoyé de mon SM-G965W en utilisant Tapatalk
  8. Always buy the best suspension you can afford. LT mean longer shock travel, not longer arms travel. Longer schock mean more "resolution", more adjustability. You should use +4+1 wheel, and +2+1 a-arms. Envoyé de mon SM-G965W en utilisant Tapatalk
  9. Did you read what i said??? Thats exactly what trail tech is telling you... Both circuits are isolated one from each other. Your dc circuit is isolated from the ground (frame/engine) You can put a capacitor instead of the batt. Look at the drawing! Envoyé de mon SM-G965W en utilisant Tapatalk
  10. The best and cleanest way to use LED is to separate lights and cdi power. So, float the ground, buy a cheap 120w ac/dc rectifier/converter, put a battry or a capacitor and be done with it. Envoyé de mon SM-G965W en utilisant Tapatalk
  11. Are you retard??? I though only kids were writing that way. Envoyé de mon SM-G965W en utilisant Tapatalk
  12. Don Viton. Envoyé de mon SM-G965W en utilisant Tapatalk
  13. Youtube it. The heat gun method works good. Envoyé de mon SM-G965W en utilisant Tapatalk
  14. I run 2% of oil. Envoyé de mon SM-G965W en utilisant Tapatalk
  15. Fucking parts changer talking shit. Envoyé de mon SM-G965W en utilisant Tapatalk
  16. Run the less octane that your setup can take. Too much octane is not benifical. Envoyé de mon SM-G965W en utilisant Tapatalk
  17. All modern port layout have boost ports. Envoyé de mon SM-G965W en utilisant Tapatalk
  18. Buy the best you can afford. Envoyé de mon SM-G965W en utilisant Tapatalk
  19. You can correct me if i'm wrong, but i see a use for them if you often change elevation. Envoyé de mon SM-G965W en utilisant Tapatalk
  20. Sure, hill climb/drag races, where is either 0 or 100% throttle. Envoyé de mon SM-G965W en utilisant Tapatalk
  21. Dear fearless leader, For the last 5 years, i followed most of your advices about banshee stuff. But, i always keep in mind that you mostly drag race. So, when you say that power valves suck or after market igntion suck or Lectrons carbs are just good for dumping lots of fuel, i always take that with a grain of salt. Yours truly, Claude. Envoyé de mon SM-G965W en utilisant Tapatalk
  22. How not having to change jets for elevation is snake oil??? Envoyé de mon SM-G965W en utilisant Tapatalk
