Everything posted by blk02banshee
Ok, thanks guys.
Use good 2-stroke oil and good gas.
Anybody know the headlight bulb #s for 02 and up? I thought they changed in 02, but can only find #s for 87 up. Every place I look has the same one listed for all years. If they ARE different, will the old bulbs fit in the newer housing?
KY=no CO=yes ($25.25) Simple google search
Could be a bad plug boot.
Sounds like it's too lean on the air/fuel mixture. Try turning each air screw (on the side of the carb bodies) in (to the right) 1/4 turn at a time, until the dead spot is gone. If it doesn't make a difference, the pilot jet(s) could be clogged. Most likely air screws, though.
The sticky glue trays do work, but when it gets cold, they're useless. The glue hardens up in the cold, and loses it's stickiness. I have caught lots of mice with them, though. Catching them isn't the problem... the problem is repelling them from the quads, tractor, mower, etc. I rode today, and found that my super stinky mexican fabric softeners seem to be working, although I did find some claw marks in the oily gunk at the end of my left silencer I guess I'll have to shove some steel wool in the ends of my pipes.
Tune it for whatever mixture you want. I run mine at 28:1, but jetted it while running that mixture. Some oils require mixing at a certain ratio, which is fine, just make sure your jetting and air mixture is right, and the motor will be happy.
I think it's a lost cause. I can't even find where they're coming in at. It's a well built shed, built like a garage, and sealed up real good. Gonna try the bucket thing one more time, although last time I had a bucket full of dead mice, AND a banshee full of mice at the same time.
Tried decon blocks, but they came in the house and died in the walls. never doing that again.
Hey all! Finally got the quads out a couple weeks ago, Cleaned the crap out of them, and cleaned the carbs & tanks. Both the banshee and 400ex are running awesome, but I still have a mice problem. Damn things ate my plastic, air filters, and some wiring. I've tried just about everything, except a cat, cause I can't just lock a cat in my shed. Right now I have some crazy mexican fabric softener sheets in my airbox and under my seat, but won't know until today if it's working. I tried mothballs last time, and the bastards built a nest right on top of them. When I had the plastic off the bashee, I think I found out why I kept blowing out light bulbs. I was going to install a rmstator regulator while I had the plastic off, but found out that the stock regulator's plug was only half way in, from the factory, so it intermittently losing connection. I snapped it the rest of the way in, but have to buy new bulbs to see if that fixed it. It's nice to be riding again, and back here on the HQ. I've been working 80+ hours/week, so when I'm not working, I'm usually sleeping. I can't neglect my quads anymore, though!!!!
As long as you have the jetting right, I don't see it being a problem.
Big Shout out to the 'ol timers!
blk02banshee replied to ledofthezep's topic in General Banshee Discussion
responsibility sucks, doesn't it. I think it's worse than getting old. I got laid-off, or I wouldn't be here, either. Welcome back Led. -
I've never had a problem with stock pistons before. Not sure i would use them with nitrous or real high compression, though.
Banshee HQ trip to Badlands in Attica, IN
blk02banshee replied to JasonsBanshee's topic in Riding and Events Forum
Man, sorry I missed this one. I couldn't have gone anyway, but glad you guys had a good time. I've been to the badlands many times, and it's always worth the trip. Maybe I'll make it next time. -
IS the idle too high?, to low? They basically need to be adjusted the same amount, but if you want to make sure they're right, you need to start from scratch and synchronize the carbs first, and then with both idle screws set at their lowest setting (slides all the way down) you need to play with each screw back and forth to find the point where it just barely is ready to pick up the slide. Do this to both and when they're both at the same point, adjust both the exact same # of turns (I think just 1 or 2) and start the motor, and see if it's too high or too low. Adjust both screws up or down, the exact same amount a little at a time, until you get it where you want it. If the "tors" kicks in and kills the motor like a kill switch, when you take your thumb off the throttle, adjsut the throttle cable at the throttle housing (usually in).
That's a baffle. It'll run without it, but better to have it. It helps keep the fuel where it needs to be, when it's sloshing around in the bowls, I guess.
Pics of your aftermarket bumpers
blk02banshee replied to lokisbuddy's topic in Banshee Repairs and Mods
TAG Metals -
Even if the floats are sticking, they should be leaking from the drain tubes coming off the bottom of the float bowls first. If they're not, then the brass tubes are probably plugged, but either way, there's a problem with the floats and/or needle and seats.
Both bowls should have brass tubes attached to them. They are vents, and are where the gas overflows if the floats are set too high. If one was missing, it would be pissing gas all the time. It's been a while since I had mine apart, but I'm sure, as stated earlier, the bowl with the little jet in it goes on the carb with the choke plunger.
I think the pro circuits are more of a mid-high pipe, but I think you will be happy with them. You'll only notice the loss of low end when you're in a tight section of woods, trying to start up a hill from a dead stop, lol. I love mine, but have never tried the gnarlys before.
Old news. Did you know that weeks after they were busted for that, they did it AGAIN? The second time, they were actually trying to keep it a secret, by telling the resort that they didn't want any signs saying "welcome AIG" or any invoices, paperwork, etc to say AIG anywhere. instead of waisting money on these greedy dumbasses, bail ME and the rest of the average joes out. Then maybe we would start spending a little more. Lets face it, our economy needs to crash, lets just get it over with.
It's temporary, at least I hope :ermm: . This economy isn't too good. I barely made 10,000 this year, and it should have been clsoer to 60,000.
I'm still here, too, although I was never high profile. I still lurk once in a while, but rarely post anymore (or ride ) . Now that I'm laid off, I have more time for the banshee again :smile: , of course no money to pay for gas :sad:
myspace.com/blk02banshee
