gusto
    47
Everything posted by gusto
  1. PWK's all the way
  2. Fattys are good pipes for low and mid
  3. Yes the stator can be bad. That should be your next check if you haven’t cut back the wires on your plug boots yet.
  4. Hahahahaha
  5. I was told these are long travel banshee arms but I’m thinking they may be possibly from another machine like a yfz450. Does anyone know the brand of these a arms? Sent from my iPhone using Tapatalk
  6. JL Engineering has the slickest unit. I used his instructions for floating the ground . Wasn’t to hard, the stock epoxy is real tough though
  7. I may have had them upgraded but don’t remember. Had to take back my tie rod ends and upgrade to yes 450 ends when they arrived. Check out Stadium shocks. They’re Canadian and will save you some money over US companies
  8. My fireball arms cane with 12 mm steering/control rods. No ball joints though.
  9. You sure those arms never shipped with 12mm tie rods? buy Stadium shocks.
  10. Definitely get the fireball arms in long travel. Not sure on the elks running. I know the first fireball long travel works with Elka stage 3s, I have them
  11. Curious to what pipe your changing to? You pretty much have your bases covered with those two.
  12. Great job on the build!
  13. Try moving your needle to last position and see if that makes it better. pipes and pods is usually automatic pilot increase, but try your needle first
  14. Your pilot is to small. Throw in a 27.5 and experiment with needle setting. Start in the middle. report back if it’s notnworking
  15. Use Tapatalk app to post pics. So you bought this top end and it’s sitting on the shelf or it’s installed? you could get away with the stock carbs I think. 800 gets you a driveline set up for fuel tire reference
  16. I personally wouldn’t put a dime into the engine. If it runs good run it until it breaks. Then upgrade. that set up is from a time before CPI and Driveline cylinders and the domes and head are specific.
  17. Nice looking bike!
  18. If you want a tough rim for a fraction of the cost look at itp baja rims.
  19. They’re heavy and overkill.
  20. JDS Customs makes foot pegs.
  21. Damn!
  22. What’s the hp on that? Nice car
  23. Look like screws for the carb to boot intake. short one looks like one of the frame bolts?
  24. Change you mains. before you got those filters really dirty how often were you cleaning them? Go with a bigger jet and see what happens. If you think your plugs are wet try smaller
  25. Wow! Love the colour
