CottonBranchRacing
HQ Site Sponsor!
Everything posted by CottonBranchRacing
  1. Ask him for a 5-2 or a 6-2. The numbers after the dash only go to 4. The numbers before the dash go to 20. If I knew the overall length of the metering rod, I could give you a start point
  2. Things were better before the old man passed away 4 or 5 years ago
  3. Ok so you're running lowlead. It's a cub, stock cyl..? CottonBranchRacing
  4. A 02XL is a(very lean) third-generation lectron gas needle. A PE1 is Dennis' smallbore alcohol needle. There's 100 different needles on the lectron graph, Dennis only has a few for common alcohol applications. He doesn't really tell people where his needles come from on the graph, theyre similar to some but they're mostly his own cut. How many cc's is your motor. , and what fuel do you wanna run ...gas .. Alcohol...? CottonBranchRacing
  5. We put 100 hp on a 13tooth sprocket, it wasn't the chain that went bad it was the sprocket itself CottonBranchRacing
  6. Stalker.. CottonBranchRacing
  7. You're about to start wishing you paid somebody to fix it CottonBranchRacing
  8. It's just good to know which combination is next in line when you're going shorter or taller(longer) CottonBranchRacing
  9. Jared is a good guy, if you ask him to help you gear for the hill, he'll be more than happy to point you in the right direction CottonBranchRacing
  10. 13/43 3.30 13/42 3.23 13/41 3.15 14/40 3.07 14/43 3.07 13/39 3.00 14/42 3.00 14/41 2.92 15/43 2.86 14/40 2.85 15/42 2.80 14/39 2.78 15/41 2.73 15/40 2.66 15/39 2.60 13, 14, 15 39, 40, 41, 42, 43 CottonBranchRacing
  11. More oil.. CottonBranchRacing
  12. It's good stuff CottonBranchRacing
  13. How much money you wanna spend CottonBranchRacing
  14. You should do whatever makes you happy CottonBranchRacing
  15. I bought a billet basket from white knuckle a few years ago and a stock hub and pressure plate that's they had machined to fit 8 plates. We ran it in the twister on the asphalt and it did really well. It was just a plainjane basket nothing really fancy about it, worked tho. Came with cushions, back plate, basket, pusher bearing, inner hub, PP. I never asked who made the basket but if I had to bet my shoes, I'd say it came from Keith's shop CottonBranchRacing
  16. PortMagic 1280 sleeved cyls 75 by 85 Crank, cases, topend, new pistons 5000 plus freight (Giveaway price) CottonBranchRacing
  17. These work pretty good CottonBranchRacing My favorites
  18. You're right at 3:1, which is fine. You could still go higher if you wanted. Id gear it where you could make a pass in just four gears CottonBranchRacing
  19. 8th mile...? 300'..? What are you doing with it.. CottonBranchRacing
  20. There should be a divot in one of the case halves at the seem where it matches to the other case half. That's where the dowel pin goes. If your bearing doesn't have a pin, that's fine, it'll be ok CottonBranchRacing
  21. I just don't see Jim being on that same list You gotta do some bad shit..for years on end to be on par with the other two CottonBranchRacing
  22. It's a 21 CottonBranchRacing
  23. CottonBranchRacing
