hoppedupandcutdown
    73
Everything posted by hoppedupandcutdown
  1. Make sure that you didn't inadvertently plug in the TORS brain box, left side front under tank, small black box - 3wire plug.
  2. It's all good....I've always liked my T5's pm replied
  3. or 1 1/4" if the metric is hard to find. (Actually my standard fits better than my metric)
  4. Remove the hose from the caliper, stick that end in your full rear brake reservoir, and pump away. When you get no more bubbles, quickly put it back on and then bleed normally.
  5. Are your slides in backwards?
  6. They are a about 3/4" short, and both are the same size tube. I'll check on shipping tomorrow, I have the box they came in, the guy I got them from sent them from back east to me, parcel post for about $30 I think.
  7. Or I would trade even up if money is an issue for you.
  8. I need to decide if I want the PT silencers, I bought a nice set of just pipes the other day. But, YES, I will take $100 +shipping for just the pipes, or $200 for the system if i decide to go that way. Tomorrow I'll figure out how I want to put it together.
  9. From what I've seen, you'd be lucky to even save a hundred on used over a new blem. Just watch their garage sale section for one.
  10. Bump, I could deliver to the HQ ride in Waynoka in Sept.
  11. I stumbled across these on Ebay http://www.ebay.com/itm/Yamaha-Banshee-Graphics-OEM/161088295517?_trksid=p2045573.m2042&_trkparms=aid%3D111000%26algo%3DREC.CURRENT%26ao%3D1%26asc%3D17058%26meid%3D665423964585652907%26pid%3D100033%26prg%3D7917%26rk%3D1%26rkt%3D4%26sd%3D161088295517%26
  12. Another pic to show you how crappy they look.
  13. They look nickel plated but over rust pits? no rust showing though... they do look odd. PT with my Toomey T5 silencers, they are the exact same size, I have a 3/4 socket in there to line them up The PT silencers, they have an aluminum stinger with an aluminum sleeve attached to slide in the pipe.
  14. I've got a pair of PT mids to get rid of, no silencers, and rough. I'll get some pics, and see if they might work with Toomey silencers this weekend sometime.
  15. Might actually be to rich for your elevation. I run 280's at 1100 ft.
  16. Your status update says 280 main and 2700 elevation, need better specs. Either way you should bump up about 6-8 sizes on the main when adding pipes.
  17. All year banshee's use the same rear rotor, you'll have to look close to figure out whats been changed.
  18. ^^Oh yeah, that would be awesome
  19. I let my son pick his own color, he went with charcoal. Different,I think it looks good.
  20. Yes, I've read to the left of the case arrow, no more than 1/8" max. Did you completely tighten all 6 pressure plate bolts?
  21. push inboard with your finger while adjusting the screw. I've read on here that some people will adjust it a little out board of the case arrow (I think that 's the direction I read I'll try to find that info if no-one chimes in)
  22. Did you try adjusting the arrows on the case/actuator with the cable completely loose yet? Did you use ATV trans 80/90 or parts store gear lube?
