hoppedupandcutdown
    73
Everything posted by hoppedupandcutdown
  1. You need to screw the adjuster IN, so the cable is completely loose
  2. That's exactly backwards of the way it should be.
  3. With the cable completely loose at the perch? If so, it doesn't matter the distance, as long as it lines up.
  4. Or use Facebook to host the pic
  5. Well, I for one am offended. Real Steel 211 is a Malt Liquor. NOT a beer.
  6. Another simple thing to check that causes intermittent dying until total death is the wiring harness down the right of the air box getting burnt from the exhaust.
  7. You didn't buy the new one he had?
  8. I'm just saying...Tomorrow it will be full month since you were given this bit of advice.
  9. What exactly do want to hear?
  10. What I meant to ask is, How do you plan to re-use old pins?
  11. You can re-use old pins?
  12. I have stock needles in mine with T-5's, cool head, K&N, EHS lid also. It's pipey as all get out, but I liked it that way. Since you have Vito's needles I would recommend the Toomey needles too, I'm planning to get some also as my old arms are getting tired of the snapping pull.
  13. Everything is basically the same except the actual plugs. Here you can get adapters to simply plug it all up or a complete new harness to anything in between. At great prices and fast service.
  14. I'm going to make it my mission to get FB people to use "sale" and "sell" properly. Why is it so hard?
    1. Show previous comments  3 more
    2. locogato11283
    3. Ayesully810
      Ayesully810
      Tyler did you ship it for him yet??
    4. Bennett131
      Bennett131
      I do I all the time, idk why people PM me but I always send them to you LOL
  15. Probably. But wouldn't it be nice to know if what you are running was the problem or not? That would make it easier to move forward in correcting your issue.
  16. You can have two of the same as long as that passage is clear. And you have yet to confirm that. need to pour not spray in the red arrow hole, got a eye dropper?
  17. WOW, I'll get my stocker out the trailer and measure again. It's been a while.
  18. not good, you don't have a bowl to feed your choke circuit then
  19. trying to follow, but... Any way, I strap a laser level to my rear tires and shoot a beam forward to set my fronts at zero toe. Then adjust a little in. One side is a little different than the other but I'm thinking way less than 1/2"
  20. Did you remove the plunger and spray cleaner up the brass tube on the left carb body while the bowl was off?
  21. that's odd, did they flow liquid through those ports I marked?
  22. 1 should have a very very little jet in the "green arrow" hole I posted, and pouring something through it will see if it is clear
  23. only 1 should have a jet. only 1 should transfer liquid from one tube to the other. Sure we are talking about the same thing?
  24. so you found a jet in a bowl? and it flowed gas? and put it on the left carb? I'm not convinced that you have a choke carb bowl.
