02Bansheeee
    02 Shee Toomey T5 Pro design Boost bottle Bored .30 over OEM Airbox W/O lid ( K&N air filter ) 35 pilots & 330 mains.
Recent Profile Visitors
567 profile views
02Bansheeee's Achievements
HQ Soldier
HQ Soldier (2/5)
7
  1. Yes it is grounded under the voltage regulator to bare frame
  2. Yes, I have spun the engine over numerous times with plug grounded to a head stud.. No arc. It is also grounded as it should be underneath the voltage regulator. The quad was bought not running and has never had fire.
  3. It has one of my old stators with an adaptor on it. The stator is still good, it fired the last time I had to use it. It is an OEM yamaha stator.
  4. I have trimmed be plug wires and put them back, no luck. & that's what I meant by "zeroing out"... Sorry for the confusion. The only reason I used an aftermarket cdi is because that's all I had available for that year model banshee (92 with the circle plug harness)... A friend didn't care if I pulled the ends off to see if that corrected my problem. I have 3 other banshees, but all of them have the newer style harness
  5. Hello, I have a 92 banshee in front of me. Buddy bought it with the guy saying it had no spark. Got it home and tested the on and off switch, kill switch, stator, ignition coil, swapped a cdi with an aftermarket one , set pickup gap, swapped flywheels, checked ground on voltage regulator, and tested for resistance on every wire in the harness itself. All wires zerod out (0.00). Does anyone have any recommendations??
  6. My billet impeller should be in today but I have figured out the issue. Ended up being the ignition coil. I swapped with another quad and it ran perfect
  7. Will do, I will get back once I find something out
  8. Funny that you ask about overheating... the last ride I took it on to try to test the jets I noticed a little bit of coolant on the swingarm coming from the hose on the overflow bottle. I also noticed a faint smell of coolant, I'll go check the coolant in a few minutes. But I ordered a chariot billet impeller today because of what I noticed, I'm 100% positive it's a stock impeller in the water pump but not sure of the condition. Dumb question, but could that cause my issue? I have a stock woodruff key and flywheel, mix 32:1 with yamalube 2R, and full engine is 64.75 bore and pistons, 115psi compression last time I checked, stock stroke aftermarket crank (not sure of brand, bought it with it in it), stock head, Toomey T5, boyseen reeds, pro design intake with boost bottle eliminated, stock carbs, airbox w/o lid and k&n. Thanks for the reply!
  9. Thanks for the reply, but no I haven't. I believe the problem is a lean issue so I haven't backed down on jetting, only up. I have cleaned carbs well. I have thought about swapping coils but still wouldn't my plug be wet if an electrical issue was present?
  10. For the last few months I've been having issues with getting full power out of the 3/4 to WOT range. It begins to sputter as if it is lean. Last weekend I did a leakdown, and had a airleak between the cases. I sealed that up and replaced the seals while I was there. Got bike all back together, did a leak down, 100% sealed up.. 6lbs for 6 minutes (didn't drop a bit). Took it for a ride and it was doing the same thing. I'm at roughly 600ft elevation, and the temperature here is around 75-90°f. It currently has 32.5 pilots, needle in the middle position, and 330 mains. Did a plug chop and the plugs were completely white as if NO fuel was getting there ( I had 310's in at the time)... not much better with the 330's. so I swapped carbs with someone else with 27.5 pilots, needles in middle position, and 300 mains and I had a verrry light brown reading on the plug... best I had gotten so far. So I swapped in my 330 mains into those carbs and once again it was back to white.. I'm frustrated and stumped. So far I have adjusted my float level to the proper setting, checkedy carbs for cleanliness, looked at reeds for cracks or gaps through the intake ( looked tight with little wear ), replaced crank seals, and I will be putting some huge jets in tomorrow or Thursday to see if that gives me a reading... does anyone have any advice on what the hell could be going on?? I'm fairly stumped. Modifications I have are factory air box without lid and a K&N, stock carbs with stock tors (unhooked), pro design intake ( ditched the boost bottle though because it went through grommets every week), stock stroke crank, 64.75 cylinders, stock head, 115 psi compression, Toomey T5's.
  11. Okay thanks!
  12. Also running pro circuit exhaust
  13. Just had an engine rebuilt, bored next size up on stock cylinders, Aftermarket hot rods stock stroke crank, Vforce 4 reeds, upgraded boss intakes with no crossover, 35mm khenin PWK carbs that came with a 160 main (unsure of the pilot at the moment), and an airbox without lid w/ K&N. Leak tested engine and it passed. Where is a safe place to start for the jetting? I'm at 680' elevation and the weather here now is about 32-55. Any advice appreciated
  14. working on a banshee for a buddy that is 2002 according to the frame, but it has an older round style harness (87-94). The engine connector coming from the stator has the white square plug like a newer one (such as an 02)... Therefore the bike has no power from the stator cause it can't plug in. The guy he bought it from said it was a ground up build and has never been started because he had " a few minor things left to do". My question is would a stator with an older plug style work on this newer engine? Or should he just get a whole new harness, cdi, regulator, etc?
  15. For the past few months it hasn't been riddden, just started and gassed to try to see if it's grounding out on something
