hoppedupandcutdown
    73
Everything posted by hoppedupandcutdown
  1. I would check the thumb on/off switch and the key switch or jumper if it has been bypassed first. Intermittent start/stop is usually something simple like that,
  2. The red arrow points to the "BB" in the left (choke side) bowl only
  3. You may have to start a new thread and expound on your problem. Coolant gets hot, expands, the system gets pressurized, that's normal.
  4. Stock Mikuni carb has an air screw. In is richer (less air) Out is leaner (more air)
  5. Front -no Rear -yes I figure it should be answered before it turned a decade old.
  6. I feel that I must commend you on your patience before your first "bump" Good luck on your search!
  7. If you're referring to the green and yellow together, yes, that way the light will come with the switch in both the low and high positions.
  8. Wow, I was about to type the exact same thing
  9. Wow, I stand corrected. I just knew I've seen part numbers for those before, but they didn't pull up when I last checked.
  10. Can't buy that part separately, new anyways.
  11. Hate to tell ya, but Justjoshinya ain't been on here since the day he posted that ad.
  12. If Alba is telling you Banshee's are measuring 10" and 10 1/2" They are WRONG
  13. Both of my Banshee frames that have had 3 different brand arms, including stock, measure 8 1/2" top and 9 1/2" bottom between the mount ears on the frame.
  14. Slide in the correct carbs?
  15. https://www.fullflightracing.com/cart/
  16. Stranger things have happened. Got pics?
  17. Certainly do not need to relocate mounts for any brand aftermarket arms. Buy them new?
  18. This had wires (all but a few, 2 or 3) broken inside the insulation. Undetectable until they completely broke. Although I've ran across it before on GM HEI distributor harnesses and if you feel every mm you can feel the soft spot.
  19. Wiring harness, I've seen one ohm test good, but in this case had the wires from the pickup coil actually down to few strands. It ran fine but would fall on it's face and stutter when the RPM climbed.
  20. Or go back to the CDI and cut and isolate the Green w/Yellow stripe wire.
  21. Not the TORS, Yes it's the park brake rev limiter switch sticking.
  22. That comes straight from my young son who's truck cost more than my house.
