BeeCanBanshee
Everything posted by BeeCanBanshee
  1. Drag bars is 45 shipped
  2. Matte black race cut laker rear plastic. 175+shipping http://m1311.photobucket.com/albumview/albums/lowery_3/plastic/IMAG0168_zps0e4037cf.jpg.html Clutch parts 70 shipped http://m1311.photobucket.com/albumview/albums/lowery_3/clutch/IMAG0127_zpsd4f346a1.jpg.html Chrome drag bars 45 http://m1311.photobucket.com/albumview/albums/lowery_3/drag%20bars/IMAG0169-1_zps82d0cb78.jpg.html Also have a stock brake hub 25 shipped Stock sprocket hub with renthal 41T 30 shipped 2 stock heads 20 shipped each Thanks guys and the stuff I don't have pics of I can get apon request. Pm for fastest response.
  3. Fuck wire nuts just twist together and halfass tape that shit.
  4. Just copy and past the http at the top in the bar.
  5. Have a shift shaft also
  6. I have clutch basket, pp,boss, screws,springs,,push rod no ball, clutch cover with water pump,stock head,stator cover,
  7. Very informative. I had a recent topic I posted asking about grounding. And just so I have.it right the first time please yell me if I.am correct... I don't run headlights at the moment so I have removed my voltage regulator so no need for a ground there. I also have nothing on my bars electrical wise other than a tether switch which.is grounded to the bar clamp. I also have my coil mounted to bare frame for ground and also am running a ground wire from my cylinder nut to the coil mount. Is this enough grounding. I believe it is but just want someone with more electrical experience to confirm.
  8. Just throwing numbers out for arguments sake.
  9. I thought dome size didn't matter as long as you compression doesn't go over a certain point and at that point you should run race gas correct? If 17cc domes at his elevation put his compression at 130 then he's good with them right?
  10. Like it says I have some 22cc pro design domes I would like a set of 21's or maybe 19's.
  11. I.got a basket,pp,boss,screws,springs and rod. I'm looking for street tires or shot dirt tires 30x11-10 or shot tires on wheels. Any size as long as it fits banshee. And they hold air.
  12. Pm'd on dirt tires
  13. X3 on the baggies.
  14. Well I already sanded the coil mounting area but just enough for the coil to contact. I'm worried about the above said engine mounts need to be in good contact cause I think the sanded off powder there would be noticeable.
  15. How much are they? If there the same as ek chains or less I think it.would be worth it.
  16. Ok so you mean make sure the front and back mounts are clean where they touch the frame? I don't have the dog bone looking mounts. And I am not running lights.
  17. http://alloyboltz.com/catalog/product_info.php?cPath=193_212_213&products_id=1628&osCsid=v8qqptpmfipdgao4jibdad5100 If the link doesn't work go to alloyboltz.com
  18. Looking for 20x11-10 or 18x11-10 rear tires really just want to pay the shipping if its cheap or I can pick up in northern va. As long as they hold air that's all I need. I'm breaking my motor in on asphalt and don't want to ruin my new dirt tires
  19. Sorry saw the wheels at the top. Just pm price on fronts
