Surfrjag
    4
Everything posted by Surfrjag
  1. Id go with a 21cc dome unless you gwt it ported then a 20cc Keep in mind your crank would be better off if it was trued and welded if you plan on putting more stress on it.
  2. So... its stock stroke or 4mil
  3. 4mil? What fuel? What elevation?
  4. Hopefully polished wheels but thanks fapper
  5. I am looking for some 5/8 spindle mount front wheels 10x2 smooth buff tires 18x4 a drag style swingarm +6 that can be used with a no link setup also interested in some street spindle mount front wheels. thanks!
  6. is your sprocket nut on right and tight? it keeps the shaft tight with the gears on it. could be a fork I guess too did you replace those too?
  7. its only in 2nd gear? the problem has something to do with the transmission but you replaced it.. does it shift thru all the other gears?
  8. American racer hoosier micky tompson
  9. did you check tdr racing
  10. there is nothing wrong with cast pro x pistons if your clearances are set properly. stock pistons are cast as well and work just fine for most. forged weisco pro lite are stronger and with all the drag banshee's it is more common to use and they don't cost much more.
  11. i have a nice set of sand geckos
  12. consider having your crank trued and welded?
  13. wicks aircraft supply sells chromolly
  14. yep billet basket from redline and a water pump seal and you should be set
  15. most have to be made to fit
  16. i got a stick head
  17. Also check your tester to see if it leaks
  18. i would leave it if I owned it myself
  19. well I thought milling down either the lockup itself or the inner hub where it bolts up would bring it closer.
  20. Dowl pins I have ran without them with no problem. Im sure its better to have them though they are there for a reason.
  21. What is the best way to decrease your air gap and what effect will it have?
  22. Get a new spring. They are cheap..
  23. Haha why not answer he may be interested in buying it?
  24. I like it to be in the middle but wherever it has 1/8 slack in cable is where it should be. The arm line up with cases like described in the manual?
  25. Stock airbox without lid 27.5 pilot 280 main I would start there and plug chop
