aleyesonme
Everything posted by aleyesonme
  1. Need some advice....I've searched thoroughly and haven't came across an answer so here goes...I recently purchased a cub motor, I'm new to the cub scene, anyway I took the topend apart to make sure everthing looked fine on the inside...I noticed that some rtv was used as the gasket and nothing else. So I had some oem gaskets lying around and used them to put it back together, only to realize later that there's a gasket made for the monoblock cub. So I want to know if the two piece gasket is fine or not.....thank you for any help
  2. Just purchased a complete 4 mil cub for 1400 shipped....thanks guys for responding
  3. Pm
  4. do they have port work? does that comes with carbs and intakes?
  5. didnt have the money at the time plus its not a complete motor.....so if someone told me they had a 4mil cub with override for 1400 are u guys saying i should beware?
  6. aleyesonme
    drag motor
    Looking to purchase a great running drag motor, cub cylinders, or 68mm or bigger stock jugs 4,7, mil...preferrably ported, override transmission complete motor without carbs or intakes. Have money in hand just won't be able to put in bank till beginning of next week since banks are closed on the weekend. Looking to spend 13, 1400 shipped give or take...thanks guys, let me know what u have
  7. Props to a great seller.......
  8. Hey bud I'm a serious potential buyer...will you please contact me at 3362553323
  9. I'm in need of a set of front skinnies tires and rims asap for a decent price. Please let me know...thanks.
  10. i went th the track myself for the first time. since the dirt tracks round here been close. mine is also a trail bike with a port job, stock cylinders stock carbs stock head. the best i got was 8.1 at 79 mph
  11. Thanks a bunch...didn't think about that...I jujst bought some gasket sealer and was gonna try that. But the tape is a good idea...thanks
  12. I just stripped my right side carb idle screw threads and the screw just keeps turning.....is there an easy fix to this or do I need a new carb...thanks
  13. How would u be sending them...and tors removed correct?
  14. aleyesonme
    stock carbs
    looking for mint stock carbs with no tors and good price
  15. do the carbs come with cable?
  16. Well peeps after three agonizing months of tryna figure out my problem, it ended up being my reeds petals the whole time. I thank u all for the help
  17. Thanks..ill make sure the float height ir right. Thanks everyone for the help. ill let u know the outcome
  18. Just did a flush...poured oil in the crank and lifted the bike upright to let all the shavings come out. Seems to have did a good job. From what I can see anyway. Had my cylinder measured and its still in spec according to the rings. So not sure where the play could occur. Unless my rod is bad. Which my friend mentioned.
  19. Out of all those options running 50 50 sounds like the choice I would make
  20. Yeah my spark plugs were backing there way out of the cylinders...which I heard or read that was called by detonation. Not really sure what causes that or how to stop it. I'm +4 timing, head milled equal to 21 domes and running 93
  21. Left side a lil whiter than the right. But not by much. In my kn pod filter I do have a slight small whole in the filter where it was rubbing against a screw. Could that lil hole cause it to lean that much of a difference.?? Also should my spark plugs be completely dry..?? Thanks
  22. Thanks bud but I figured it out. Had to crop the pics.
