ban565
Everything posted by ban565
  1. Forgot to mention that the exhaust flanges can be changed between small flange and big flange pipes and the intakes you can stock reed cages or cr125 cages. Also go an look up twistercrankshaft.com
  2. What specs are you looking to find out? It comes many different bore sizes. I have 10mm with a 75mm bore and the cylinders can be bored out.
  3. if it is 85mm and stock stroke it would be a 612cc
  4. you buy them at twistercrankshaft and for more info call louie swan at 15036637711
  5. If you mean 64.25 that is 10 over that 10 over other it is 60 over
  6. Check out the October 2010 issue of Dirt Wheels.
  7. You talking about the native grass that came from europe?
  8. It is not wine it is whine.
  9. Do not buy vitos and buy from twistercrankshaft
  10. Twister and I only had to give him my first born but it was worth it.
  11. I run two quarts.
  12. Blendzall 40 to 1 smells great
  13. If you want lowering gearing you will need to lower the number of teeth on the frunt spocket or raise the back. Remember that changing the front one tooth it is the equivelent three on the rear.
  14. Sorry I did not state that it will be trans fluid. The hose you are looking is some kind vent for the trans. If it was like a stock set up the hoses would keep it from leaking. My cousins does the same thing because he has his vent running down the swingarm. If I make to Tucson I will flying in. Hope I made clearer this time.
  15. I just looked at my banshee and the vent hose ties into the hose coming the water pump area than it goes under the tank. If your hose is going to the back of your banshee it will still leak out the hose when verticle. thanks for the offer to ride.
  16. Do you have the reserve bottle still connected? If it is not than the oil will flow out the the hole on top of the upper case when verticle. Like to get to tucson this winter. My daughter lives there.
  17. the system was made that way i will to get buddy to do the pics. iam not every good at that stuff. it probably will be this weekend. the boost bottle was drilled and has nuts welded on for nozzles.
  18. not a problem that is were here to help.
  19. it engages if the parking brake is not fully disengaged but it also engages if there to much play in your clutch lever. happen to my cousins 97. drove us crazy until the dealer had us check. problem solved
  20. if your banshee is 95 96 a rrev limiter was also connected the the clutch lever. to much play in the cable will activate it. any year newer has the limiter for sure.
  21. yes it will work well. i have a nos wet system and that is how it is set upand it adjustable from 5 to 18 hp per cylinder.
  22. try a product called liquid threat to hold the helicoil in place
  23. Starting in the mid 90s if there is to much play in your clutch lever it will do same thing.
  24. I have a 10 mil 565 motor and I can play all day long with my grandkids. However I have to run it hard every so often to clear out the motor.
