ban565
Everything posted by ban565
  1. Riva motorsports in Florida 10 2GU-14112-20-00 ...VALVE, THROTTLE 1 (UR FOR LEFT) 1 113.99 10 2GU-14113-20-00 ...VALVE, THROTTLE 2 (UR FOR RIGHT) 1 116.99
  2. I have a twist throttle on all banshees .
  3. ban565
    Fox float 3
    I'm putting them on the drag bike.
  4. ban565
    Fox float 3
    I ordeed fox float 3 Wesnesday
  5. Call cascade innovations
  6. Twistercrankshaft is another option
  7. Is the actuator twisted?
  8. Look on Portland craigslist there are a few on there.
  9. hydroplanes have a fighter jet cover and the floor has a door in case they are upside down. you're safe
  10. maybe a circlip came out
  11. It won't be put together until friday before easter. Maybe next year
  12. I'm headed to juniper to test and tune the drag frame Beverly sounds like a good time.
  13. My big block and small block use cr125 reed blocks.
  14. hell yeah twist throttle is the only option
  15. It is a safety that would make sure the parking brake was fully disengaged.
  16. check the play on the clutch lever. If there is too much it wil idle but will not rev. This happen to a cousins son and it was a 97 model.
  17. I am taking a guess and say the stator is chinese. I bought one off ebay and it was wired the same way. The only way to get it to work is to reverse the wires. I through the junk in the gargage. Lesson learned.
  18. barnett clutch and direct drive lockout
  19. Polished Billet Aluminum Neutral Switch Cover & O-Ring Part: NSC-GY REPLACE YOUR CRACKED OR OLD NEUTRAL SWITCH COVER WITH THIS LEAK PROOF BILLET COVER! $ 26.00 Quantity: cascade innovations or your local dealer
  20. A longer rod does not increase the cc. Only bore and stroker crank will increase cc.
  21. I agree with specialblend. I have a bike at 114hp 62tq and it shifts very well.
  22. Green is not cranky he has the burden of caring all those chins around lol
  23. Sure looks the same
  24. 165 mains,60 pilot and dgh needle 3rd clip on my 10mil smallblock on 110 race gas
