ban565
Everything posted by ban565
  1. ill be there on pres day weekend i will be at juniper on sunday
  2. ill be there on pres day weekend i will be at juniper on sunday
  3. hopefully i will be there in 2 weeks
  4. Are there videos of the drag races of labor day 2011? If so where can I view them. Im tring to make for pres day.
  5. Boone I will be at Juniper for Easter weekend for sure. I might there for pres day weekend. I was raised in the tricity area.
  6. Moses Lake is a waste of time unless you want to ride in a small area and want to dodge rocks and gravel. Ive rode there too and what a waste of time.
  7. I use to live 13 miles from juniper and live in Hood River Or. I was there last Labor Day and I ride a 565cc banshee. Where you doing the drag racing that weekend?
  8. Buy heat shields from cascade innovations.
  9. If the id of the pipe 7/8 inch then you have small bore cpis
  10. As i stated earlier measure the end of the pipe. CPI makes different sizes stinger but not silenters.
  11. no, you measure the end of the pipe
  12. the end of the pipes are an 1/8 inch dirrerence. big bores 1 inch id and the small bores are 7/8 inch id.
  13. I dont know if parking brake and the amount of free play in the clutch is hooked together. If there is to much free play in your clutch it does what you are saying is happening.
  14. Ive ran direct drive clutch for years with no problems.
  15. Old school. It is an air cooled kaw motor in the 70s.
  16. yes the rush is worth the cost.
  17. I have a 4mm and 10 mm twister crankshafts and I am happy with both. My 4mm is at 7 degrees and my 10mm is at 6 degrees
  18. Stock are good I ran them on my 4mm stock. It is your crank you need to be concerned with.
  19. I run 39mm intakes.
  20. I have v3s on my 10 mil an didnt have to trim any tabs.
  21. I bet they have 20 hp boost bootles
  22. Buy a wet system because less jetting problems at least that has been my experience. timing shuold be 3 degrees advanced, Iran b9es plugs and I ran 160 lbs of compress. You should have your crank welded and trued if not already. Hope this will a good starting point for you.
  23. I ride a 565 twister which I dune all day long as well drag race. It has the hp for drag racing as well the reliablity for duning.
  24. The stock length will work. I think stock is 104 pins.
  25. That is a great motor buddy has that motor. It has awesome hp.
