wfobasheeboy
    6
Everything posted by wfobasheeboy
  1. I got an intake you may like, will pm you some pic.
  2. I have a set of billet intake for 34. I will PM you some pic. WFO
  3. Failed No PIC
  4. dEcon Nice jobe on the screens. I have the same problem with the toomy sparkys filling up with packing too. i think you just have to clean them a lot
  5. Yes the dam tree huger This is bullshit.
  6. Good luck with it. Keep us updated & post up some pic of the sheared part
  7. For the O-Rings just use a little grease on the O-ring to keep them in place.
  8. now that is funnier then shit! :rotflmao: :rotflmao: :rotflmao: :rotflmao:
  9. Any time
  10. dEcon I will look tonight when I get home. I think I have a good pickup coil. I will let you know.
  11. WOW :whoa: I wish I had the cash for this one. That is one nice JOB you did there Free bump
  12. I would swap it out. You can pick them up for cheap these days.
  13. Well if the carb are set up for alky that is what it will do flood the motor out on gas. Check the jets you stated 180 but is it realy 180 or did the ass clown drill it out to make is own alky jet? When you buy a banshee from a ass clown you will need to go back to basics for checking shit out. We will need more info on your set up to give the best help.
  14. Looks to me the pins in the new & old conter are the same. So I would try to pull the pins out of the new conter & put them back in the old conter. That way you do any soldering. And if the pins are diffrent the just cut & solder as stated above.
  15. The stops are at the bottom of the steering stem @ the lower bearing on the frame. Just like Fouledout421 said they get bent forward. Just need to straighten it back up & you should be good to go. Also you will have to replace any worn parts like bushing & ball joint that will help out a lot. WFO
  16. I have a set of new NGK caps. They have 3 rides on them. Pm me & we can work something out. or Here is the link for them https://www.sparkplugs.com/results_appOther.asp?otherMotiveID=212898&mfid=1
  17. looking good is there a update to this build?
  18. ^^^^^^^^^^^^^^^^^^^^^ :rotflmao: :rotflmao: :rotflmao: I use amsoil Dominator oil @ 40:1.
  19. The flywheel can be high keyed. This means the crank key moved when you put the fly wheel back on & make the fly wheel off center & rub the coil pick up in spots.
  20. I would like to say Marty is a A++++ seller. He has Fast shipping, great communication, awesome prices. I got my kicker today from him it is very nice. Do not hesitate to do business! Thanks WFO
  21. Ditch the whole box & lid and go to pods!
