xtankx
    Qc, Canada
    2002 Yamaha Banshee 368cc with a few mods.
xtankx's Achievements
  1. Still looking for some cheap YFZ front shocks!
  2. Looking to buy some yfz stock shocks in good condition. Do not come up in my thread my different alternatives OR saying i'm better to stick with stock banshee shocks. That being said, post what you got! Thanks
  3. TTT!
  4. Today is a really fresh day out here (about 2 degrees farenheit) so I don't know if it contributed to this BUT.... I've been able to idle the bike for a good 15-20 minutes without fouling any plugs... Beetween that 20 minutes, I went down the street twice to give it some and never fouled a plug... What I did? I replaced the carburetor cap rubber seals that were ripped and cut and put up some new ones I made out of a bicycle tube. Also volcano, I'll look into those b8es plugs you are talking about. Thanks for advice. I'll also get some longer screws for idle adjustement. Now, we'll see if it last! Thanks for help! Frank
  5. Idle screws might be a part of the problem but not all of it.... There are rubber seals under carburetor caps and mine are in pretty bad shape. Could it be a part of my problem?!
  6. Alright, couldn't put some time on my Banshee this week and today I took off the choke plunger, cleaned it out and changed the oring.... Now, seems like it will just NOT IDLE cause of the screws. I know of a shop where I live that sells the longer screw + spring kit... I might just go for that. So for now, engine starts, warms up and idle goes so low that motor stops. What's next ? Thanks for help everybody!
  7. Hey, Looking for a set of hanguards with mounts. Needs to be in good condition and BLUE or BLACK. Thanks
  8. Not trying to be a b**** but there are tons of thread in the "For Sale" section being updated each hours selling the exact stuff you're asking for. So I think you'd just have more chances to find what you're looking for browsing those threads. My .02 or a Free bump.
  9. Not only Clymer tells you how to do it, but it tels you what tools to use and such info. Lots of other stuff you might not even think of is in that book. This manual is a must for all DIY home mechanics.
  10. On the idle screws, there's the nut that holds the screw in place.... I could loose it and use a spring..... I haven't touch to choke plunger yet BUT, can I remove it without having any issues like, gas flowing out.... (I plan on putting the petcock on off before doing it)... Thanks for help Larry
  11. PM sent for plastics!
  12. Just hooked up a Clymer's ... This winter is gonna be fun!
  13. Just hooked up a Clymer's ... This winter is gonna be fun!
  14. Like I said a couple of posts up, High rev trouble seems to have disappear since I dissassembled carbs, did some cleaning, put em back in place carefully.... Maybe it was just some air going through a misplaced/loose component, I dont know actually. But I fired it and I was done with the rev problem. Now the engine still dies on itself... I let it sit on idle and plug keeps fouling on left cylinder. Like Larry's Shee said, it could be the choke plunger o-ring being worn/cracked which could cause a gas leak, just enough to make it run too rich on one side... It sounds pretty plausible cause I noticed that my plunger isn't smooth a all when I try to pull it out or in.... Also, I think that my idle screws aren't long enough to catch the sliders so adjusting idle with these is useless...
  15. Hahaha today was pretty cold out here.... I'm supposed to run around 250's on main during summer time and still was a little rich so I went 2 pts up for a 270 .... Might be fine now. I'll let you know when I get this done!
