wfobasheeboy
    6
Everything posted by wfobasheeboy
  1. 3 more days to Pismo sand run
  2. 3 More days to Pismo Run!
  3. Welcome to BHQ.
  4. I used zip ties on my fuel lines on my carbs & pingle. Worked good & no leaks. I would use some type of clamp on the lines for safety Even if the lines do not leak without clamps. Just my 0.2cents.
  5. Got the shee running . Time for a test run to day.
  6. Just over week until it's time to go to Pismo . Just completing shee now
  7. Ok I am in. I have a head count of 13teen going as of now. There could be more we will have to see. Let the count down start.
  8. Nice to here it was the coil. I have not rode mine yet so I do not know if it fixed mine yet. I will let you know.
  9. SP Yes I can see that too. I would use a needle bearing for the same reason. Thank again for all of the info you helped me out a lot on this. WFO
  10. SP Thanks I will work on that mod next time I have the case split.
  11. Hay SP thanks for the info. I can not find any info on the shift drum bearing did you due that mod too? If so can I get it from the same place as this bearing ?
  12. Yes the show was smaller this year then last year. But like you said it was fun to walk around & check out some stuff. I saw the occ bike too it did look better there then on TV.
  13. X2. I would like more info on where to get the bearing at. Also part # if you have them.
  14. Is any one going to the Sand Sport super show in Costa Mesa this weekend? http://www.sandsportssupershow.com/index01.html
  15. Any one going to the sand sport show in costa mesa this weekend.
    1. SuperMex
      SuperMex
      Yeah i'll be there on Sunday
    2. So Cal Suspension
      So Cal Suspension
      Carlo! I'll be there Sunday as well. I'll be there with Austin, who was with me when I met you at Pismo. I'll be there about 9am, hit me up and we'll meet up!
    3. wfobasheeboy
      wfobasheeboy
      Cool matt. I will hit you guys up on sunday. Chuyvargas. Hope to see you there if you like u cam pm your # & I will hit you up on sunday too for greet & meet.
  16. I'll add to the positive feedback for JDS Customs, I just got one of his BHQ rear brake rotor from him & it is very nice. The rotor is a perfect fit. I'll definitely be doing business with JD again. Thanks again JD. WFO
  17. LOL :rotflmao:
  18. I have very good luck with my gopro. I like it a lot.
  19. banghead Hate that when it happens.
  20. I Am having the same problem with my shee right now. I have replace the stator with a new one when the bolt back out of the old one & F it all up. I have check all of the grounds & cleaned them. Clean & lube all of the plugs. Tested all of the wiring all good there. tested the coil & it tested fine. So I was thinking the coil is failing when hot So I replaced it with a new nology coil & wires from fast. I hope to test it this weekend. I will let you know if it fixed it for me. Good luck with it & keep us posted.
  21. Here is a pic of the mod to the shift shaft on my shee. I have a Mull mod shift star, mod shift shaft, shift pro arm & spring. She shift like great. On the next rebuild I would like to do the bearing upgrades.
  22. Free bump I wish I had room for a second shee.
  23. X2 on the Electrosport. That is what I am running in my set up & works great.
  24. Bump for good seller & a great ride.
