BigMatt
Everything posted by BigMatt
  1. well, will I be ok with +4 because my compression is around 120-125psi I do not have a milled head but do plan on a coolhead with 20cc domes in the near future? I just do not want to have to worrie about hurting my motor but would not mine some more power. should I start with +3 then how do I know if its to retard or advanced?
  2. I dont want to blow threw a new topend thats all should I start at +3 first?
  3. how will I know to retard or advance? my mods are, trail port, fmf golds, pods, and then stuff I dont think matters like oversized radiator and high flow impeller along with inline cooler.
  4. what do you mean? I run 93oct pump gas, will I have to add race gas with +4 timing, because I want to just stay on pump gas,
  5. will timing effect jetting?
  6. not broke but mostly sripped out and bolts constantly backing out, I dont know... just trying to stick to american parts. I'll let you know though. is yours used? because $25.00 for used is alittle high because online there going for that brand new.
  7. this is by no means a show bike, I just have heard bad things about the cast ones, If I get no bits for billet ones I'll let you know thanks man.
  8. thats a great price thanks man
  9. ok thanks i did it right
  10. great seller fast shipping and honest, will buy again!
  11. I have just heard bad things in the long run about cast, and dont want problems in the middle of no wear. well see if I get any bits... if not i'll check out the cast ones
  12. rate now in the wanted section i have a post looking for a adjustable timming plat no cast junk, anyways have a few questions, if I advance my timming will it take away from my bottom end power? will this help me even though I trail ride, can you advance your timming with a stock head or do you have to run smaller domes? and in order to run a cool head with smaller domes do you have to advance your timming? I have a trail port and wesco pistons, stock head and was wondering whats the best advance +4? will this hurt my motor at all, and am I on the edge with +4 or is +4 just fine for my mods, I'm looking for more reliable power. thanks, Matt
  13. is thats whats wrong with mine? If I kick it real slow it wont grab but as soon as I kick it fats it grabs every time. also when installing the clip there is a little loop that sticks out where does this face? I lined it up to slide into a hole in the case is that right?
  14. I'm looking for a adjustable timming plate no cast junk, and must be in good shape with no damaged threads, thanks Matt
  15. if anyone else trys this let me know what you think.
  16. on my other one the head snapped off so I just drilled it out and re-tapped it, if its stripped though you could just use an EZ-out.
  17. Ya... I gotta say those things are ugly, the real raptors are nice looking bikes those arn't. I still think the stock plastics are the best looking thing, alot of people think the banshee is ugly but I always thought it looked like one tuff SOB, I even like the stock over fullbores I'm not a big fan of all the roundness. but those rear plastics look nice.
  18. got some on the way thanks guys
  19. I just asked this question not to long ago, and the same awnser T.M. so I went with it... its a little more cahs for just being plastic, but you can see how it fills all the voids and braces everything, get it like I did, and dont look back.
  20. ya I'd like to see what it looks like, because I have two bikes and if someone has a better stock mod I'd try it on the next one.
  21. the size of the O-ring was 3/4 x 9/16 x 3/32 #11 O-ring, theres gotta be more of you out there with different remedies
  22. I think all the packed grease just stops the rattling all together
  23. I went up to my local hardware store(ACE) and picked up the O-ring and a metric grease fitting, the tap size i dont remember but just look at the pitch and drill accordinly than tap, its like the kicker was made for a O-ring there was already a cut around the edge for the ring to press in, i just brought the kicker in and tried different rings till one fit I can try to find the bag and get the size for you.
  24. has anyone else tried this also?
