BigMatt
Everything posted by BigMatt
  1. how old is the radiator.... radiators do go bad if they get a build up in one of the channels, on cars you can get them rodded but for some thing this small its alot cheaper to just buy another one. are you dumping coolant into the overflow? any crossed hoses? make sure you ran the small head coolant line threw the small steel loop so that your head breather is not pinched between the gastank and frame. all in all sound like your on the right track, but one thing for sure is you sould do a leak down and rule out a head gasket. the banshee coolant system is very simple so you'll figure it out is something stupid.
  2. yes stock cap does fit so if you buy another type cap it'll work, I bought a new stocker and just polished it up looks great.
  3. i run one, the guy from honk kong is pretty nice guy, he alway awnsered my questons. i have noticed a 7degree diff from stock to this, so my vector says. all in all well made just a cheap cap.
  4. i was talking about crank case oil
  5. does neverdull put a protective wax or something? its shined up real good so I dont need a polsih more of a wax or spray.
  6. I have just polished up my clutch cover and its flawless I went over everything with a fine tooth comb, My question is once polished is there a good product out there like a wax or something you can spray on to give it a protective layer aganst hard water marks and stuff? I dont want to keep re-polishing all the time... but damn it looks good.
  7. I had the same problem, trail tech when back and forth with me for over a month, I ended up getting the vector with a remote. I like it much better now. Its more race tunned with maintenance update and timmings. I saw no point in the tach read out other than it looks cool, its to inaccurate to tune off of, and if you need shift lights GET OFF A BANSHEE. and there is no remote for the vapor to control from the bars, that made a big difference rate there. there are alot of guys out there that have had this problem and then there are alot who have not, its a gamble but if I could have done it all over I would have just went with the vector. I dont know if you could contribute this interference with a cleaned up harness or tores eliminator or what all I know is trail tech could no iceolate the problem I mean I was on there tech support so much I could build the damn things I know them inside and out so if you got any install problems shoot me a PM, but I would just get the vector its hassle free and I think is better.
  8. thank you sir, also you know of any good diagrams of how it all assembles in the cover?
  9. I need to install a new impeller bearing and was wondering if there are any tricks to pressing this in without ruinning it, I looked around for a bearing press and found nothing but pullers, I dont mind buying a tool, I looked on harborfreight(I know there not the best place but there pullers are alright) thanks
  10. I have installed a few of these, for a power input I and trail tech recommend hooking it up to a 9volt battery. the banshee electrical system is to noisy for the vapor and will interfere with tach read out, but the problem with hooking it up to a 9volt battery is that it will only light up half the backlite screen LED's so it appears as dim as the the internal battery, my salotion hooking up two 9volts in series to equal 18volt you'll have the same run time as a single just dubble the volts. the vapor will than be as bright if not brighter than the stator, lighting all the LED's. I have this setup and love it, I call trail tech before doing this the vapor can handle a whooping 400volts, so your safe. here is a link to my photobucket to see my setup http://s682.photobucket.com/albums/vv182/mattrentz_2009/Yamaha%20Banshee/ and here is a link to hooking up two 9volts in series http://media.photobucket.com/image/9%20volt%20battery%20in%20series/zakkwyldefan79/EMG%2018v%20Mod/EMG18VoltMod3.jpg
  11. I'm looking for some decent paddles for my 1999 banshee, I priced out my local shop its about $200.00 for new mounted on some dougies so let me know what you got. also I'm looking for polished alloy not colored rims, the finish can be ruff as long as I can buff it out, like water stains and light scratches let me know what ya got. thanks
  12. what are all the seals in the clutch cover? is there just the impeller seal and the kick starter seal, and where is the place to get these? I'm changing out my clutch cover and want to update all the seals thanks
  13. alot of times when people get the motor back in they cross the over flow lines, thus coolant dumps into the overflow bottle rather than circulating, the tallest point on the radiator is were the line going into the overflow bottle goes(the fitting on the radiator cap stem) then the small 1/4inch hose of the head goes on the lower fitting on the top right of the radiator(the small turned down fitting)
  14. i hit a 109mph.
  15. i played around with this and in the long run ended up with the trail tech mount, one trick though if you plan on going the battery rout hook up two 9v in series a total of 18v you'll have a brighter back lite screen and the same run time as single, thats what i did, here is the link http://s682.photobucket.com/albums/vv182/mattrentz_2009/Yamaha%20Banshee/
  16. looks great man, nice work, reminds me of my jeep delta light bar.
  17. mu... mu... mu.... mumma says.... I'm 6'4'' and let me tell ya things really are'nt built for me. I have heard to if you weigh alot not to run them, also wheres a good place to buy them?
  18. high flow impeller, good collant, and larger radiator some say a cool head but nevr noticed a difference here
  19. I was wondering I hear all this talk... good and bad about lighter fly wheels, my mods are +4 timing, wiseco pistons, trail port, FMF fattys, Pods. and wanted to know if this would benifet me, I mostly trail ride, and I am about 275lb if thats matters, I heard something about that lighter fly's dont carry kinetic energy.
  20. when you heading to silver lake me and a few friends are goingreal soon, I'm looking for some paddles rate now, and a set for my buddies polaris outlaw
  21. I have a clean 1999 I picked up for $1,500 with all the mods you listed
  22. man, I just had a ruff day at work and your post brought such a big smile to my face, Im sure I gave the joker a run for his money. funny shit man im sure everone is wondering what Im laughing about so hard in the den.
  23. I run a 14-46 for trail riding andthe rear sproket just clears the stock skid, I also weight 275
  24. also how do i know its set all the way in, is there a torque setting. i think i have a stock key, it does not have any groves or steps.
