BANSHEE HP
HQ Site Sponsor!
    10
Everything posted by BANSHEE HP
  1. Get slp pipes if you are looking for a trail/woods pipe
  2. What is doing or not doing? I wouldn't doubt if the jets were 130-140 mains, those pipes are not pulling any rpm or flowing anywhere near what a good pipe does.
  3. Die cast better than oem. Sent from my SM-S901U using Tapatalk
  4. You're in the back of the bus as usual Sent from my SM-S901U using Tapatalk
  5. Theyre 192° exhaust port. Kinda an in between'er but low 190's is what we've had good personal experience with. Its been super hard to keep the website updated or even add cylinder kits to it before they're already sold/spoken for with the parts shortages and the extremely long wait time on plating. Partially why we made a sleeve to install in our casting. All the labor of installing, port match, bore and hone is done in house vs sending them to plating at Millennium for almost 3 months. Sent from my SM-G965U using Tapatalk
  6. Were doing cylinders with steel sleeves now. 4mm stroke 64mm starting bore. Sent from my SM-G965U using Tapatalk
  7. I still call bs. Literally hundreds of ppl have bought cylinders from us in a year the exact way you say you didnt. Lane say hes left no email or voice mail unreplied. Good luck with bp racing Sent from my SM-G965U using Tapatalk
  8. I dont think you've called during business hours or left a voicemail. Sent from my SM-G965U using Tapatalk
  9. state side campsite #511 forsale $125 for the fall bhq ride
  10. if its a stock head that's what the squish is supposed to be … 2 miles. get an aftermarket head with interchangeable domes/combustion chambers.
  11. he'd have to go back in time 6 years to have langcourt plate his cylinders in the usa or send them to the UK where langcourt is.
  12. post pics
  13. I did a 421 58x68 and a 424 64x65 this past season. The 421 made 2hp more than the 424. Ported very similar but I would say the 421 had a touch more work.
  14. correct, were not cutting oem heads anymore but we got deez drivelineperformance.com/yamaha-banshee-stealth-head/
  15. definitely, there are not many 424cc cylinders out there to begin with and this ones bad
  16. . Sent from my SM-G900V using Tapatalk
  17. In the back, down into the rear jackets first, then the flow will come up the 2 side and 2 from jackets and find its way out Sent from my SM-G900V using Tapatalk
  18. 424cc 10mm stroke 65mm bore drag ported Assassin cylinders. 3 dyno pulls on these bmfers made 110hp with shearer small pipes and 40 pwk carbs on methanol. Will include cylinders, pistons, gasket, studs and domes (a head can be added also stealth or billet). $1100 shipped for bhq members. Sent from my SM-G900V using Tapatalk
  19. Driveline Performance $180
  20. Turbo chassis
  21. thanks, it probably is but its just what the it could make bolt on no dyno tune
  22. Drag ported 446cc Driveline Performance Assassin cylinders. Includes cylinders, studs, gasket, o-rings, 70mm pistons, domes and chariot super cub head. 110-115hp. The cylinders will be sent to Millennium for plating next week, you could expect them to be done by the end of November. $1400 Sent from my SM-G900V using Tapatalk
  23. never happen, new buyer is a tire kickin mofo
