fleury_xlt
About fleury_xlt
  • Birthday 03/30/1989
    Alma, QC
  • Interests
    Emission OFF diesel trucks, 2 stroke ATV, Turbo snowmbile, V8 Superchaged cars
    Blue 2003 Banshee, 10mil stroked 521 Cheetah Cub
Recent Profile Visitors
fleury_xlt's Achievements
  1. Yes they are pretty nice. Look’s like a brand new product. Cannot find any infos or videos of people who tried them. They cost a little bit more than OEM cases and was wondering if it worth it. I thought they would be nice with my Cub setup. Thanks ***Claude, content de voir que tu es encore actif dans le monde des Banshee !
  2. Hello, Unfortunately i’ve broke my cases on my Banshee and was wondering if anyone have any input on Driveline cases ? Does it worth the price ? Same alloy, casting method as OEM ? If you have experience with these, I would like hear it please ! Thabks
  3. LMAO it's French, but you can answer in english with no problem !
  4. Message Facebook (Messenger) envoyé !
  5. Salut ! Merci pour la réponse, je m'attendais pas à me faire répondre en français :D. La raison du C-14 ; c'est tout ce qui était disponible chez Équipement Villeneuve ! Alors, suis-je mieux d'en rajouter 25% (C-14) pour être sûr ? Merci !
  6. *** 0.051'' squish
  7. Hi everybody, Just finished my 472cc Super Cub built. I need to know how much octane gas to put in it. Here the specs : - 155 Psi on each cylinders - 0.0051'' squish - 27cc domes - Timing +4 - Fuel and oil ratio 40:1 mix - Clean up port - Elevation : Around 300m above the sea I've just bought some C14 to mix it with 91 octane pump gas. I'm kind of scare to run 91 octane with the specs above. Waiting for you help guys, Thanks
  8. I've just putted out the reed cage and saw that the carbon fiber petal was broken in half. Time to put V-Force !! Problem solved, thanks everybody !
  9. Yeah an air leak could be a good idea, when I start it, the engine is reving really fast on one cylinder. That is weird !!
  10. Try swapping plug wires see if problem follows - Done The spark plug are both ''brown chocolate'' And finally i've checked the float inside the carburator and they work properly. Stil have no idea about this problem, any other suggestions guys ?
  11. Hi guys, today I was drag racing with my friend when sudently my Banshee start running on one cylinder. I've checked the spark plug, coil + cap (interchanged the spark cap on the plug), cleaned the carburator, checked the reed valve and i'm at 130PSI on each cylinder. The gas flow on each line of the carb, the air filter is clean. I've tried to put directly gas in the cylinder that is not working, without results. So basicly I have AIR, FIRE and GAS and the quad is not working properly. Really confused about that. Any ideas ?
  12. And the electric problem ? What could it be ?
  13. Thanks for the idea !
