xTHUNDERCATx
Everything posted by xTHUNDERCATx
  1. Inframes with silencers: these are in EXCELLENT condition 1 ride after fresh chrome from cpi's chromer. There is 1 very minor dent in one side and there is a burn mark on one of the stingers from a wrapping we put on to help protect the air filters. only problem is there is some bubbling on the seems near the flange (this is the best picture i could get) its on both pipes but they are pretty much identical so i only took a pic of one 375$ plus shipping OOF small bore small flange unsilenced cpi's 1 out each side one dent that is pictured other then that in pretty good shape and ready to run 350$+ shipping
  2. intakes still for sell 45 shipped, 250+ shipping of the carbs, 100 shipped on the reeds (in the main 48), and 170 shipped on the stock cylinders jsut trying to get rid of a little bit of this to buy some other stuff
  3. im looking for a lock up/cover or shearer small flange big bore oof's unsilenced 1 out each side if anyone is interested in working out a trade 35.5 mikuni carbs set up for alky by ftz, i bought these from phelps a while back but ended up changing the build plans so i needed bigger carbs and never ran these they have 114 dump tubes in them 275+ shipping v-force reeds also bought these then changed build plans so i no longer need them 100+ shipping 1-5 over ride transmission cut by rudy kurtz i just bought this form performance atv and ended up getting a 2-5 i would rather run instead. just want what i paid for it 300 shipped stock bore/port cylinders they might be able get get away with a hone but no promises they ran well and got pulled off for the drag build, they wont have head studs im keeping those 200 shipped stock reeds/intakes 15 shipped billet intakes 55 shipped stock clutch cover a little bit of chipping i must have dropped it on something offers? im not sure what its worth front brake system worked fine when i took it apart, its all there offers? polished stock cylinders, i got told they were drag ported. bigbore 68 mm sleeves but the sleeves will need to be replaced i dont know anything else about them they came as spare cylinders with the basnhee i bought and offers on these, ill pretty much give them away because i cant even promise they will run well if you have them resleeved
  4. i bought some straight cuts from him, quick shipping and they looked good when they got here thanks again chris
  5. im looking for stock ratio straight cut gears and a lock up clutch and cover send me a price+ pictures if you have either thanks chris
  6. we are starting to get nervous, were still waiting on a cdi and a stator for the banshee that needs to be here before the weekend
  7. what kind of port work do you have on that 330 strm trpr, and thats a stock cylinder big bore? damn thats big lol
  8. were did you relocate the cdi to?
  9. yep he got back to me im just waiting on a shipped price for the swing arm and pingle so unless he skipped me those are as good as sold
  10. pm sent on swing arm and pingle
  11. im looking for either a 7 mil crank in great condition or a set of stock ratio straight cut gears let me know if you have either one thanks
  12. i cant send you a message what brand is it? if no one else is in line yet ill probably take it
  13. are they stock timing plates or adjustable?
  14. fortn and rears? or one or the other
  15. i agreed to hold them tell thursday but there are 2 others in line if for some reason the deal does fall through
  16. sold pending payment
  17. up, i got told the dent i have pictured was actually designed like that, so other then that these are in excellent shape make me an offer
  18. if you decide to let go of the pipes send me a message i would be interested depending on the price tag thanks, chris
  19. find a bolt/nut combo that is long enough,use washers the fit inside the piston but hit the wrist pin, use a larger washer to keep some seperation between the wrist pin whole and the bolt end, as you tighten the nut the smaller washer will push the wrist pin out towards the bolt head
  20. up top, these are awesome pipes someone has to want them all mounting hardware for the silencer is included
  21. up top, i want these gone
