Larry's Shee
    6
Everything posted by Larry's Shee
  1. Probably lean on pilot or needle. Might not even be right anywhere, PO slaped some parts on and called it gudnuff.
  2. Nine Mile is close to Eight mile, where all the hoes be !! Oh, wait, that's DEEtroit.
  3. Stator noise could be bolt backing out and hitting flywheel. Should have done a leakdown test before teardown, air leak còuld be causing deto.
  4. Where're you at in the Murder Mitten ? More info on truck.
  5. Pics or you're a lying homo-demo.
  6. Thanks for saving me the effort, guys !!
  7. Umm, aluminum cyls are are cast around iron liner. They have a keyway on the outside to prevent movement.
  8. I have no experience with those pipes, but sounds like you should be close. Have been ridden this set up yet? If so, how did it feel?
  9. Surprised it still runs with only 90psi. Might should have tried another gàge. Makes sense the right would misfire if crank is out. If you get another crank, get new seals too. How is your country on shit being imported?
  10. Also just cruise the for sale forum.
  11. By the looks of that carb, should have gave that pig a bath before you started working on it.
  12. Carb Parts Warehouse, Sudco, Jets are Us. I would just get float needle & seat, gasket. Unless you're bone stock, the jets that come with kits won't work.
  13. You forgot temps and elevation. Really, only you can tell if it's jetted right. Either with plug chop or read.
  14. Fuck, took so long to type my shit there were three more posts.
  15. Wow, just wow !! You put Windy city John to shame !! Do you write speaches for politicians ?? Might be best to try the Cliff notes/short form version. EXAMPLE : I have Xxx main Xx pilot Needle x clip Make and size of carbs My mods are: Air filter setup ( lid/no lid, type of filter, I know you have pods) Type or reeds Type of porting (if any) Name of exhaust you have Now list riding conditions : Elevation is xxxx feet above sea level Average temperature is XX Type of riding ( dunes, trails, drag, etc.) Now list your specific problem. EXAMPLE: I have a bog (or miss) at full throttle. I think I detected abit of sarcasm. When you are new, you just have to suck it up buttercup and grow some thicker skin. And sponsors like JD /Shee rips do that, let you know what they offer. Might pay to check out his web site. Offers parts and services you'll find no where else. As to your compression, see what size domes you have (cc) get larger to lower comp. For leakdown tester I use a Harbor freight and two PVC caps that fit carb boots. Drill hole in one to force thread adapter into it. Turn compressor down to about 10lbs, use tester regulator to bring up to 6-7 lbs. Not sure on description of plug chop if you are doing it right. Read up on it, always use new plugs for each test whether you cut them or read them. As to jetting, we can only suggest a range, YOU have to test and tune. What was your question again ?? LOL
  16. Hope not talking ugly ass Raptor looking shit?
  17. Also check reeds, use new gasket. Might try 30 pilot. No name parts that may or may not help, or even hurt FTMFW !!
  18. Also pull the reeds and inspect. If not sitting tight, chips, crazy, or cracks replace. New gaskets and don't King Kong the bolts. Might try 30 pilot. Buying no name parts that may or may not help or even hurt FTMFW !!
  19. Because the Banshee fires both plugs every time it hits a nub you can't tell of that spark was for the right or left. If the right nub had a wider gap it might not fire on time, if at all. Or might be weak. I don't know enough about the system go answer that. As to running I don't know shit about single carbs. However I see no mention about reeds. Might be time for new, or at least check them.
  20. Thing is odds of something great coming from China are about the same as something shitty from 'America. Plus, if I'm going to buy shit,, it might as well be 'American shit.
  21. What the fuck are you even talking about? When you posted this he still had two carbs.
  22. Pull Stator cover, clean timing nubs on flywheel and set pickup gap.
