shawn941
Everything posted by shawn941
  1. also says its 700cc's,,,,lol. he really believes,,,or is trying to get someone to believe his plastics are real carbon fibre,,,,not carbon fibre look. maire just puts a thin film over there regular plastic.i also told him his banshee would not go 117mph unless he wanted to put another $10000 in his motor and gear it right. i explained all this to him and told him if he didnt believe me to just google bansheehq and post these questions ans see what kind of answers he gets,,,,lmfao
  2. man with all this damn rain i hope its not too muddy,i know the west side of it was horrible the last time i went,,,,i be there sat if i dont have to work.i'll be laughin at all the ppl that cant make the big hill,,,,,shits funny.....
  3. im up for it,,,went a few times last year.....
  4. as far as bumping up compression hell yes they work,,,as for cooling the engine better i have heard varying things......
  5. my idle screws on my pwk 28's are not plastic,,,maybe they have switched recently or something
  6. this happened to me once,,,i was adjusting the idle screw on my left carb(keihins) and tweaked the throttle cable a bit,,,fired it up and shee was wide open,,,just make sure your cables have not been pulled out a little bit,the slides wnt look like they are open bit shee will be revving like a bitch. just moved my cable back and shee was fine!
  7. belray mc1 is not injecter oil,,,the hc1 is,,,,if you were refering to me
  8. lmao,,,fuck the seat being wet,,i dnt want water in my carbs,,,,l,ol
  9. shawn941
    realtors?
    i agree,,,,i run the ohtsus and they hook great in the pea graval hills and sand and dirt,,,,i watched a guy on a modded banshee with holeshots not make this hill twice before he gave up,,,he was pissed because i hit 3rd and shoot right up easily,,,,he wasnt very happy,,,,,lmao
  10. banshees dont like water bro,,,sucks it right through your filter into your carbs,,,if you like riding in water,,,get rid of your banshee
  11. if your gonna keep the bike mostly stock,,,t6's are a good choice,,,if you plan on porting and carbs, reeds, adjustable timing plate,,coolhead,,etc. toomey t5's respond much better to higher mods,,,i'd go with the t5's personally,,,,i run klotz super techniplate,,burns clean,,,doesnt smoke and smells super great,,,i also ran belray for many years without ever loosing a topend
  12. your correct,,,400ex's came with them also,,,,
  13. oh ya,,,it said the axle should only be installed by a highly trained mechanic,,,,lmao....thought that was funny as hell
  14. i agree man,,,on top of the manual sucking, they sent me the wrong shit. if i would have gotton both snap rings and not some extra spacer it would have been easier to figure out without there little instruction sheet,,,,lmao
  15. ya i figured as much,,,they sent me some small spacer(other than the larger one for brake hub) and i was like what the hells this shit? well i called rmatv and they are sending me another one,,,,gotta wait longer i guess
  16. just recieved my g-force axle for the shee,,,question is,,,,is it supposed to come with 2 c-clips, one for the sprocket side and one for the brake hub side??? i only recieved one
  17. "joe" out in his garage,,,,lmao
  18. oh ya,,,as far as the oil where the pipes connect,,,there is an oring in each pipe,,,they prolly need to be replaced,,,,,
  19. ya,,,j b weld will not hold up to gas,,,it will work on your cases tho for a quick fix if you ever crack it. cant remember what the floats are supposed to be set at.
  20. also,,,if you ever decide to buy new rims,,,,make sure you order the right ones. being you have an 89-90 model,,,the hubs are a different size,,,they are 4/156,,,i believe 89-90 are the only years to use this bolt pattern,,,,all other years are 4/115,,,if you ever buy new rims just get the 4/115 bolt pattern and buy some new hubs,,,they are cheap
  21. sorry....i just read your other post,,,they are stock pipes,,,if you are gonna run her without a lid on the air box u may want to bump up your mains a bit,,,shee may run a bit better for you. also,,,you may as well pick up a set of pipes for her before u rejet for the no lid on airbox i suggested,,,cause your just gonna have to rejet again when u put some decent pipes on,,,u will be amazed at the power increase when u add just pipes and rejet her,,,you may also bump your pilot up to 27.5 when you add the pipes and you will be going up quit a bit on the main..you do have some work on that thing but for $400 wth.......
  22. what are your mods on the bike? usually a bone stock banshee with stock pipes and everything run a 200 main,,,if you have aftermarket pipes your jetting is waaaay off. even u run it with the air box lid off you are gonna have to rejet,,,tell us your mods
  23. go to babbitts online.com,,,they will have every stock banshee part available,,,be prepared to pay though
