06specialedition
Everything posted by 06specialedition
  1. Ouch
  2. I don't know......but i'm sure someone will chime in!
  3. Chariot is the way to go. I run the ultra high flow full kit. Here is some options for ya: http://motors.shop.ebay.com/i.html?_from=R40&_trksid=p3841.m570.l1313&_nkw=Chariot+banshee+impeller&_sacat=
  4. I've ran a gear from Mull for about 1 year with no issues. Mull's quality is top notch, I've talked to Brandon a few times on the phone and the guy knows his stuff. I've seen too many plastic gears fail to even consider running one.
  5. ^ My favorite post so far
  6. Did you jet up for your air filter change? Make sure your carbs are synced and there is a little slack in your cable, but not too much.
  7. Good setup, I agree with Sleeper on running 50/50 race fuel
  8. What length of shocks are the LSR A-arms for?
  9. I should have a painted black one off my 2006. I can check for sure when I get home from work tonight. How much you looking to spend?
  10. X2, no winter riding for me. Spring, summer, and fall i'm down.
  11. Some people just kill me
  12. I would stick with 21 inch fronts. 23's are going to be HUGE on there. To give you an idea on how it will look, my bike has 21 rears and 21 fronts.
  13. I wouldn't even think twice about it......STELLAR!
  14. Looks killer BKM Is that axle much lighter than the stock one?
  15. Great deals here! Whoever needs a swingarm should take advantage of these prices. I LOVE my Stellar swingarm
  16. I swapped out my front mow-hawks for some smoothies....I like them IMO front tires make a world of difference.
  17. Hell of a build, good job!
  18. I've heard guys cutting the carb springs. Make sure the springs stay the same length. There is a thread on exactly how to do it, use the search function i'm sure you'll find it.
  19. I run right around 150psi or so. I havent checked it in awhile though. I'm running 19cc domes right now. At our elevation I know people even run 18's on pump. But I wanted to be on the safe side so I stuck with 19's.
  20. 6K-8K elevation, you would be fine running 18cc domes on pump gas. You may be able to get away with some 17cc domes at that elevation, just depends on your compression. IMO anything around 165psi and up should run race fuel.
