i had another look today when i got the chance, and yes you are right. they just blended in with the metal that i did not notice them. they are really hard and thought the bushings were metal.
thanks guys.
which bushings should i be looking at? can you guys make recommendations of which ones i should be buying off ebay?
i must be confused, the bushes look like they wont slide onto the shaft/pin. the bushes i took off dont look like the standard bushings ( see photo below) the pin is the full length of the arm which no room for the bushes to slide in. correct me if im wrong.
are these the bushes im meant to be buying?
http://www.ebay.com.au/itm/NEW-A-arm-Control-arm-bushing-set-Yamaha-Banshee-350-YFZ350-1987-2006-/390358542337?pt=Motors_ATV_Parts_Accessories&hash=item5ae32ea801
I've pushed the pin in so u can see there is no room/gap for the bushes.
hi guys, i need to replace the bushings on these arms, stock replacement bushings look like they will not fit these arms so i need to determine what brand these arms are.
Thanks in advance.
sorry if photos are too large
Hi guys, I've pull my water pump apart to find that the plastic impeller is rubbing on the metal plate cover. See picture
Should I be replacing this with a new one or is this normal? First time pulling it apart so in not sure if it's ok or not.
Thanks
i had a simirlar problem. started it up, took it for a little ride and was idling high at times and revving out like crazy with my finger off the throttle. do you guys think this would happen because it was cold or do i have a problem?
