dbdragracing
dbdragracing's Achievements
  1. Praying for her too! Good Luck.
  2. How much wider do the YFZ arms make the Banshee? Do you have to buy long rear axles? My suspension is stock and I do a lot of trail riding and some drag racing...I need some suspension help!
  3. Just got my new Snap-on compression tester and rechecked each cylinder 3 times...it came out 120/122. Just curious, but if my jetting is perfect and I maintain the quad...how long should I have before a rebuild? Thanks.
  4. How do you install a new head...is it just bolt on? Also, what domes should I get? Thanks.
  5. Will that effect my compression numbers? Thanks.
  6. I removed one plug at a time to do the compression test...one plug was always in while doing the test. The temperature outside was around 60 degrees and the bike hadn't been running. I really hope its just the carbs...I ordered rebuild kits for both carbs, but it will be a week or two before I can work on them...my Wrangler just took a crap today! Any guesses on what my jetting should be with my mods just so I can check what the previous owner had done. Thanks for all the help .
  7. Well first Im going to find a better compression tester...if anyone has the name or link to one I would appreciate it. Then if the compression doesn't check out, I thought about sending the cylinders to Lakes Motorsports...I saw them on Ebay and they do the top end for $299 including the machine work...anyone know anything about them? I really hope it doesn't need a rebuild right now because it was running awesome the other day and starting easy. When it started getting hard to start I noticed gas dripping from one of the vent lines off the carbs...people told me to rebuild the carbs and all my troubles would go away. Also, I have done plenty of mechanical work...how hard is it to do the topend for your first time? Thanks.
  8. What is a good compression tester to get? Thanks.
  9. I have a Actron / 2 1/2 in. Standard and Metric Professional Compression Tester Kit from Autozone. This one: http://www.autozone.com/autozone/catalog/a...equestid=128196 What do I have to rebuild to get my compression up? Thanks.
  10. I checked my compression today and my numbers were 110/108...are these ok? Mods in my signature. I've just been trying to rule everything out because the bike won't start...when I bought it about 3 weeks ago, it fired up first or second kick and ran awesome. Next Im going through the carbs. Thanks.
  11. How are you determining the temperature...what gauges are you using? Thanks.
  12. Im powdercoating the frame and cleaning my Banshee up and I want to get my steel Toomey T5 header/expansion pipes coated in either a very shiny silver or chrome. Where is a good place to get this done? Is the Jet Hot coating any good?...I emailed them for a price and they never got back to me. Thanks.
  13. I would like to have my stock springs powdercoated...does it hold up? Are the stock springs powdercoated from the factory? I just assumed they were painted, but since Im getting a bunch of other stuff powdercoated might as well do these too. Thanks.
  14. Sweet...thanks for all the help guys. It looks like my key switch has been deleted.
