98_shee
Everything posted by 98_shee
  1. If you look at the of the carbs where the slide go in there should be a little window, your slide has a little hole or notch in it, it should line up with the window at WOT. hope that helps.
  2. Do you have stock carbs? and do you have the sync tool? To use the sync tool, (first take the filters or airbox of) tighten the throttle cable untill it starts idleing a little high then put the adapters on the sync tool put the tool up to the back of the carbs and look at the needle adjust the cables on top of the carbs until the needle is the same on both of them then let it idle and measure the air flow again with the sync tool and adjust the idle screw until the carbs are the same, then set the idle back up and double check it.
  3. 98_shee
    Billet Pegs
    Any one have any billet pegs, bumper, grab bar? let me know what you have and how much.
  4. How much for the flywheel, and do you have a rear caliper. Also interested in the timing plate, let me know how much you want for each item shipped to 72761. Thanks
  5. I have set of lights pm me if interested.
  6. I got some stuff from my local steeler shop called blue job (its a powder), you may be able to find it somewhere else alot cheaper than i found it, but it works pretty good.
  7. Found the tail light on ebay its the second one I have had the first one had blue led's this one is red, I lost the first one when my old shee got stolen. When i get the money i want to change plastic.
  8. Here's mine MySpace
  9. They should be around a 1 1/2 out, you may need a bigger pilot, what is your current jetting, and mods, does the bike idle now?
  10. Payment sent on clamps. :thumbsup:
  11. Request sent
  12. Here's what you need http://www.bansheehq.com/forums/index.php?showtopic=94210
  13. this may help Electrical faq
  14. They sound like v-2's to me, can you post a pic of them?
  15. :yelrotflmao: :beer:
  16. Its 98_shee ^^ lol :cool: and no problem.
  17. If a ex and z400 beat you there is something wronge with your bike lol, what kinda money you wanting to spend, get you some good pipes, port work, carbs, it just depends on how much you want to spend.
  18. did you put the balance tube back in between the carbs?
  19. This should help, Banshee Electrical FAQ It ^^^ will give you the resistance for the coil and stator, i don't think you can test a cdi, but not sure someone will chime in, that knows more than me.
