notsed
Everything posted by notsed
  1. I cant see why it wouldnt
  2. notsed
    key switch
    Need a 2 wire key switch and key, turns out that causes high end miss too, then no start, then WTF!
  3. isnt stock bore 64mm?
  4. sorry guys he wants to much for it to be worth my while, thanks for the interest
  5. ohlin fronts stock rear they will fit any banshee, if i get it ill sell whatever people want, just trying to work out a deal with this guy to see if its worth it or not
  6. delete
  7. pm sent
  8. notsed
    stator
    pm sent
  9. if its a stock stator than you cant run them, they wont get bright
  10. Ok either your floats are off by a bit, your needle and seat arent sealing, or you have a leak somewhere, The drain screws on stock carb bowls can be a pain to get sealed sometimes, you might want to take them out make sure there clean and put them back in, but ill bet its your floats.
  11. X2^^^^
  12. Thanks Ricardo, good luck with the build
  13. but he will clean it for the right price tho, sounds like a good deal
  14. they do make slip ons for those pies, at least they used to, i had a set, dont know what i did with them tho
  15. notsed
    stator
    looking for a good 200w or above stator, floated ground would be a bonus, thanks
  16. i have a complete set of a arms 100 shipped tight balls joints
  17. i have the same problem with my shee, same carbs and stock ignition, never had the problem till i got the 35's
  18. house ac =110v banshee ac = 12v, ya it should work, you just need one for each light
  19. notsed
    coil
    got one thanks
  20. ok thanks, i didnt end up getting them
  21. can anyone tell me what works thses are and what the set is worth? 16" fronts and 15" rear off a raptor, thanks
  22. yes you will loose bottom at wot, but if you roll on the throttle theres no difference that i can tell
  23. notsed
    coil
    need a coil stock or aftermarket, as long as it works. thanks
  24. this has bee gone over again and again, use the search function or gtfo!
