i ride 96 banshee
i ride 96 banshee's Achievements
  1. ride it tell it blows
  2. what kind of paint did you use for the frame? and the engine ?thanks
  3. running on one cylinder you should check your piston rings on that side ..
  4. check the chock tube between the carbs thats what happend to me you need to sync them and tune the carbs like the air screw and idle ect... did one side through more smoke than the other?
  5. hey guys, what would happen if you hooked up led head lights to the banshee head light wiring? i have some round led 12volt lights, dont wanna risk damaging them. if they cant be hooked up straight, is it possible to use a wall converter to convert to dc? like the ones that come with computer speakers, mag lights, ect...
  6. i need help does the thumb throttle assemble of a 94 blaster fit a banshee ? i need a answer fast thanks
  7. did you check the hose between the carbs i lost it at the dunes and my top end went out and it was the left side too check it out
  8. ill look in too that savage thanks for the info bansheesandrider
  9. i have a twist throttle for my banshee with the tors eliminator kit but dont like it i want to switch back to thumb what do i need ?
  10. i did not mean 500 i was using my ipod i meant 1500
  11. i had the same problem check there is a holes that goes in the middle of the carbs check if you have it if you dont put it it goes from carb to carb if you have it next step check your pistons
  12. Any one have some stickers or Graphics i could have... im new to this
